1. swatguy51's Avatar
    I seem to have random camera light flashes that I can't seem to tie into any specific app or actions. Using an application permission app I tried disabling any permission to use the camera on every app I could find. I don't have any flashlight apps other than the stock one. Anyone else have this issue or have any thoughts.? I am on Verizon and got the phone within the first couple of weeks the s7 Edge came out. This has been happening a long time and I keep thinking a software update would fix it but doesn't.
    02-03-2017 10:10 AM
  2. anon(9983233)'s Avatar
    Possible Solution:
    http://forums.androidcentral.com/spr...going-off.html
    IE: Reset or adjust your notifications
    02-03-2017 10:13 AM
  3. swatguy51's Avatar
    Flash notifications is off and was never turned on. So still searching for a solution.
    02-03-2017 12:38 PM
  4. Stacie A's Avatar
    I've been having the same problem as well. Has something to do with the camera. If you look at all open apps, you'll find that the camera is there. Go to it or close it & the flash will stop. Not sure of exact cause or representation yet but I'm digging.
    swatguy51 and Angel Todd like this.
    03-27-2017 03:54 PM
  5. swatguy51's Avatar
    I never did find the solution but haven't had the issue since upgrading to nougat. But thank you for the response.
    03-27-2017 04:00 PM
  1. Camera photos disappeared
    By Swimdolphin685 in forum LG V10
    Last Post: 02-08-2017, 08:47 PM
  2. LG G3 alarm going off randomly
    Last Post: 02-03-2017, 09:11 AM
  3. How can I fix the camera on my tribute 2
    By Diana Lynn Jenkins in forum General Help and How To
    Last Post: 02-03-2017, 08:34 AM
  4. How can I fix the camera on my tribute 2
  5. camera doest works, sim card isnt detecting
    Last Post: 02-03-2017, 12:50 AM
