View Poll Results: How's your battery life under Nougat on the S7 edge?
Voters
19. You may not vote on this poll
  • Better
    5 26.32%
  • Worse
    7 36.84%
  • About the same
    5 26.32%
  • Screw you, I don't have Nougat yet!
    2 10.53%
  1. Wizzy's Avatar
    How's your battery life under Nougat? Despite advanced Doze, factory resetting, and lowering the resolution to 1080, I'm getting worse battery life than Marshmallow. Not happy since it seems every update takes away a little battery life. This is the unlocked Exynos processor.
    02-04-2017 03:49 PM
  2. anon(9408097)'s Avatar
    I've gotten the best battery life ever on any phone. Easily 6 hours. 7.5 if I use a little lightly. Not exaggerating. Unlocked exynos as well.
    Maybe it's an app which is causing the drain. Check settings.
    KPMcClave likes this.
    02-04-2017 04:30 PM
  3. anon(9408097)'s Avatar
    Screen shots attached.
    Today was a medium use day I'd say.
    Mostly YouTube and browsing through social.
    All on WiFi though.
    I get usually around 5 hours when running mobile data.
    And this is on high performance mode.
    Check apps.
    Use device maintainable app.
    02-04-2017 04:34 PM
  4. crystinonfire's Avatar
    My s7e used to last me 2 days. After Nougat, my phone went dead last night even though the battery was at 50% when I went to sleep and I had the phone in airplane mode. Since my phone went dead, my alarm didn't go off this morning! Wiped the partition cache today and am hoping that helps.
    03-02-2017 06:01 PM
  5. Tsepz_GP's Avatar
    That's not good at all.
    If it died at 50% that is not due to Nougat, your battery may be the issue.
    03-03-2017 02:26 PM
  6. crystinonfire's Avatar
    According to the battery stats, it didn't die at 50%. I put it in airplane mode when it was at 50% and it proceeded to drain down to 0% (and then turn off) while I was asleep.
    03-03-2017 03:59 PM
  7. Tsepz_GP's Avatar
    Oh, apologies, read your previous post wrong then.
    That is very odd, it shouldn't drain so much.
    Not sure what you have installed but here are the apps I Disabled and I get great battery life
    03-03-2017 04:02 PM
  8. crystinonfire's Avatar
    I have all of those disabled as well. What's eating up all of my battery is "Android System" it had hogged 40% according to my battery manager.
    03-03-2017 05:47 PM
  9. pontiac005's Avatar
    Did you wipe the cache? Mine is getting about 7 hours on good use.
    03-07-2017 06:28 PM
  10. Lepa79's Avatar
    Verizon Nougat here. Amazing good battery. Much better than marshmallow. Last night, phone went from 61% to 59% while asleep. Just freaking amazing. Loving it.
    03-07-2017 08:42 PM
  11. Wizzy's Avatar
    Would like to get some more votes.
    03-14-2017 04:55 PM
  1. Blu Life One x Dual Sim
    By Jmmorales in forum Blu Android Phones
    Last Post: 02-07-2017, 06:39 PM
  2. Samsung S4 Battery Draining when switched off.
    By daymoth in forum Ask a Question
    Last Post: 02-05-2017, 06:56 AM
  3. Battery life bar
    By Redpoppy in forum Ask a Question
    Last Post: 02-04-2017, 12:55 PM
  4. Blu Life One X HELP
    By Jmmorales in forum Ask a Question
    Last Post: 02-04-2017, 12:52 PM
