1. Georgi Tapalilov's Avatar
    Hello. When i turned on today camera i noticed there are strange horizontal lines botton on my camera. Lines are not only on screen but on photo too. There are always same. I mean they didnt change. I attached photo and screenshot.
    - phone is never been dropped
    - never used in water or splashed with water
    Best regards,
    Georgi
    Attached Thumbnails Horizontal lines when using camera-20170207_171639.jpg   Horizontal lines when using camera-screenshot_20170208-001901.jpg
    02-07-2017 04:22 PM
  2. ratsttam's Avatar
    If the lines show up on every picture taken, and look exactly the same, (and they're too sharp to be lens damage), than you've got a problem with the camera sensor itself. It's unlikely that there is a software bug causing this.
    pontiac005 likes this.
    02-07-2017 05:05 PM
  3. lammy8's Avatar
    Clear the data in your camera app, wipe the system cache and reboot. If the problem is still there then it's a hardware issue
    02-07-2017 06:37 PM
  4. Georgi Tapalilov's Avatar
    Its not camera app. I make factory reset and result is same. S7 is in warranty so i will use it.
    Best regards,
    Georgi.
    02-08-2017 11:26 AM
  1. Replies: 2
    Last Post: 02-07-2017, 06:12 PM
  2. Replies: 0
    Last Post: 02-07-2017, 09:47 AM
  3. Moto Z play Wifi is always on even when i turn it off
    Last Post: 02-07-2017, 05:17 AM
  4. Replies: 1
    Last Post: 02-07-2017, 03:39 AM
  5. Replies: 0
    Last Post: 02-07-2017, 01:53 AM
