Recently I've had a significant increase in battery brain. When idle I will see up to 8 percent drain every hour. I just did a factory reset and it's the same result. I use the exact same set up on two other devices with no issues. I use Nova and the setups are the same down to the home screen layout on all my phones. Any ideas?
