1. keystone_56's Avatar
    Recently I've had a significant increase in battery brain. When idle I will see up to 8 percent drain every hour. I just did a factory reset and it's the same result. I use the exact same set up on two other devices with no issues. I use Nova and the setups are the same down to the home screen layout on all my phones. Any ideas?
    02-09-2017 06:31 PM
  2. keystone_56's Avatar
    Another screen shoot
    02-09-2017 06:34 PM
  3. wrich2005's Avatar
    Mine was doing the same exact thing. I factory reset it and it went away. I think it was a rogue news app. I disabled background data on almost everything, along with almost all apps that use my location. Good luck
    02-09-2017 10:15 PM
  4. keystone_56's Avatar
    Here are some more screen shots. Very minimal usage, pretty much sitting on my desk. Any tips on spotting a Rouge app would be appreciated. Thanks
    02-10-2017 11:25 AM
  1. RCA Cambio 10.1 battery drains even when shut down
    By Bonkfast in forum Hardware Hideaway
    Last Post: 02-12-2017, 01:32 AM
  2. Replies: 2
    Last Post: 02-11-2017, 01:22 PM
  3. S7 Edge Rooting Question
    By Freakster1 in forum Samsung Galaxy S7 edge
    Last Post: 02-09-2017, 08:48 PM
  4. Replies: 1
    Last Post: 02-09-2017, 06:42 PM
  5. Replies: 0
    Last Post: 02-09-2017, 03:55 PM
