03-01-2017 07:53 AM
59 123
tools
  1. lammy8's Avatar
    And the device up time
    Tsepz_GP likes this.
    02-24-2017 06:23 AM
  2. Who884l5's Avatar
    Went to look at other threads and other people are claiming that reseting app permissions fixed their overall battery life. Will post my findings at the end of the day.
    02-24-2017 01:56 PM
  3. Tsepz_GP's Avatar
    So it's hit 3 hours with 54% battery
    Very nice.
    Here's a setup I am trying now to get even further, I will give it a full run tomorrow, I'm playing around with Power Save settings now:
    Here's what I have done in terms of Animations:
    02-24-2017 03:50 PM
  4. lammy8's Avatar
    Very nice.
    https://uploads.tapatalk-cdn.com/201...d7d8c72af0.jpg
    https://uploads.tapatalk-cdn.com/201...492c364ce4.jpg
    That's what I have mine set at, animations are all set to 0.5x bar the last one which is 1.0x.
    02-25-2017 01:45 AM
  5. lammy8's Avatar
    Yeah? Please do, see if it makes any difference
    02-25-2017 01:46 AM
  6. WingLT's Avatar
    Through the first cycle I had gotten over 6 hours of OST and the battery lasted a long time. Then recently it lost 20%-30% charge twice now in the past 2 days. Last night it was at 56% then dropped to 21%. Something must be wrong. And I only had 1 hour of OST now. I did download two apps recently so I just uninstalled them now. Also disabled some of the new apps that come with the 7.0 update. I also noticed it's taking longer then usual charging up on my charging pad. How do I reset the app permissions? I noticed there are settings for each app. But isn't there a setting to do them all at once?
    02-25-2017 01:44 PM
  7. Who884l5's Avatar
    Before nougat my battery was terrible. Mostly ruined by a security patch sprint added. Will post my findings ad the end of the day.
    On that note i did reset app permissions. Its found in application. I also noticed that youtube is running rampant in the background. When o first updated the phone wasnt sleeping. Now it sleeps like a baby and i gey plenty of life from it.
    Today my phone lasted 10 hrs overall with 5hrs and 44mins sot at 19%. Was giing to post a screen shot but i started charging my phone...
    02-26-2017 03:44 PM
  8. lammy8's Avatar
    https://uploads.tapatalk-cdn.com/201...1e3d5b6d87.jpghttps://uploads.tapatalk-cdn.com/201...32844462a3.jpg
    App preferences didn't help me, don't think there was an issue for me.
    On WiFi I get great battery life, nearly an hour of SOT per 10%
    03-01-2017 12:29 AM
  9. Captpt's Avatar
    I have to say in my case battery life improved a ton since updating to Nougat.. I only difference in my use is I utilize Device Maintenance at least once a day (even made a shortcut to make it easier to run)..
    03-01-2017 07:53 AM
59 123
  1. 3500 mAh battery for S8 Plus :(
    By illdini in forum Samsung Galaxy S8 & S8+
    Last Post: 03-28-2017, 02:30 PM
  2. music volume after nougat
    By Crabby Abie The Queen T-Flo in forum LG G5
    Last Post: 03-06-2017, 10:54 PM
  3. Nougat on LG5= Total Fail
    By PRoland in forum LG G5
    Last Post: 02-25-2017, 07:05 PM
  4. Nougat on Sprint
    By bigmo555 in forum Samsung Galaxy S7 edge
    Last Post: 02-22-2017, 10:32 AM
  5. Which Nougat features have you found?
    By Guytronic in forum Axon 7 & Axon 7 mini
    Last Post: 02-15-2017, 02:45 PM
