As standard that's true. Think of the backgrounds like in settings, dialer etc as default. They're all white. Though I've changed that, there just seems to be an overall drain during the battery cycle.
That drives me crazy too... I'll be reading a post, put the phone down to do something, and when I return, the timeline is refreshed and the post I was reading is long gone... Nowhere to be found.I just hate the Facebook app so much... I want an app for facebook that remembers where I left off so I can start reading there.
Still downloading Nougat now, but have any of you guys done a factory reset? I always found that after a major update a factory reset really helps battery life. Backing up on smart switch while nougat downloads as we speak.
Running no power saving mode here for the first few days has been quite acceptable. At home, wifi and strong cell signal, 1-2% per hour when idling. Out and about with signals varying (no wifi) 3-4% per hour. Total screen on time per day runs about 2 hours for my average use, I don't play games or watch movies in my average day. Only a few days, but at least as good as MM and maybe better.
This is me yesterday
Overall
//uploads.tapatalk-cdn.com/20170222/62976f09aaae12046b86c95df649b496.jpg
SOT and still had over 25% battery left
//uploads.tapatalk-cdn.com/20170222/8d4ce1a9e6fd56a0ccebfe8ab64da645.jpg
Wow, pretty outstanding. Care to tell us you radio settings, internet usage type and other settings such as screen brightness?
GSAM data is welcome to, I'd like to see what your android system processes are like as I'm unsure if I'm getting a lot of wakelocks.
