troshs
Trusted Member
Hi there,
Not much has gone into it, I currently have the phone set to 3G/2G (Auto Connect) as 4G is incredibly spotty where I am.
I am mostly on WiFi which helps A LOT. If you spend more time on 3G or 4G you simply have no chance of getting great results, the Modems in these phones eat through the battery at an alarming rate at times when signal is poor.
Brightness is around 45%
Here's what my bar is sitting at:
//uploads.tapatalk-cdn.com/20170222/02117959505a420c01b667abe68b2939.jpg
Here are the apps I have disabled:
//uploads.tapatalk-cdn.com/20170222/a58e9177de53ec8a5979cfb8f1a049cf.jpg
I hope this helps.
I fully believe being mostly on WiFi is really what helps, otherwise I don't use Power Saving and I set my Display to WQHD as FHD really didn't make a difference.
This is what I do, my iPad Air 2 LTE works as my 4G LTE hotspot at home, at work and in my car, it helps a lot.Definitely, thanks for that.
I noticed earlier at home that on WiFi my consumption for the first 10% gave me just short of an hour SOT which would be staggering. Though I imagine running certain apps would decrease this, but even if that's reduced a bit it's better than I have normally.
Biggest problem I face is signal, my work has really low signal and I force LTE to get the quickest speed. Gonna try and set up a WiFi hotspot with another device and see what the difference is.
Very nice.So it's hit 3 hours with 54% battery
Very nice.
Here's a setup I am trying now to get even further, I will give it a full run tomorrow, I'm playing around with Power Save settings now:
//uploads.tapatalk-cdn.com/20170224/619c20ad23df684b17cf4fd7d8c72af0.jpg
Here's what I have done in terms of Animations:
//uploads.tapatalk-cdn.com/20170224/1b4d192c8aa06408ae2cca492c364ce4.jpg
Went to look at other threads and other people are claiming that reseting app permissions fixed their overall battery life. Will post my findings at the end of the day.
//uploads.tapatalk-cdn.com/20170226/4b496d90ea1a3b2999b2831e3d5b6d87.jpg//uploads.tapatalk-cdn.com/20170226/d5abb11d3c0659b226525c32844462a3.jpg
Before nougat my battery was terrible. Mostly ruined by a security patch sprint added. Will post my findings ad the end of the day.
On that note i did reset app permissions. Its found in application. I also noticed that youtube is running rampant in the background. When o first updated the phone wasnt sleeping. Now it sleeps like a baby and i gey plenty of life from it.
Today my phone lasted 10 hrs overall with 5hrs and 44mins sot at 19%. Was giing to post a screen shot but i started charging my phone...
