1. bandofbrothers2112's Avatar
    Hi,
    I'm in the Uk.
    The screen on my Samsung Galaxy s7 edge is being replaced due to the known issue of a pink vertical line.
    I purchased this from a Samsung Experience Store which is at the moment owned by Carphone Warehouse.
    They have approved engineers in house who are carrying out the work under the 24 Month Manufacturing Warranty. I bought the phone in September 16.
    My query is -> Would the IP68 dust- and water-resistance Ingress Protection rating be compromised ?
    02-11-2017 10:25 AM
  2. ToddK's Avatar
    If done correctly, it shouldn't.
    02-12-2017 07:01 AM
  3. gavo360's Avatar
    Hi,
    I'm in the Uk.
    Same issue with my s7. Took it to the samsung repair centre in sheffield on friday, they say it will be ready in 2-4 working days.
    bandofbrothers2112 likes this.
    02-12-2017 08:38 AM
  4. bandofbrothers2112's Avatar
    Yes I was told mine should be done by Wednesday.
    Using the *#o# and choosing the different colour resets didn't help or the various Pixel fixing apps.
    Pushing on the top part near the front facing camera made it go for a short while but then came back. From what I can tell from past discussions it's something to do with the connection there from the screen to phone.
    The guys at the Samsung Experience Store which are actually Carphone Warehouse but badged up as Samsung told me that on 1/3/17 Samsung are buying out Cpw Samsung Experience Stores with a 50/50 ownership.
    I hope yours is resolved by the screen Swap too @gavo360
    02-12-2017 09:18 AM
  5. cbs1507's Avatar
    Do you know what caused that pink line?
    02-12-2017 03:43 PM
  6. AxlMyk's Avatar
    Read the post just previous to yours.
    02-12-2017 08:03 PM
  7. bandofbrothers2112's Avatar
    I came across a YouTube video of a person who appears to be a phone engineer who had unhinged the screen away from the phones chassis which showed what happened when he touched where the connection between screen and phone was made.
    It seems a weak point to my untrained eye.
    02-13-2017 01:57 AM
  1. Why do my apps keep closing in one to the home screen
    Last Post: 02-11-2017, 10:24 AM
  2. Replies: 1
    Last Post: 02-11-2017, 09:55 AM
  3. Replies: 0
    Last Post: 02-11-2017, 08:35 AM
  4. Replies: 0
    Last Post: 02-11-2017, 08:17 AM
