1. smalba's Avatar
    Is there a process to get the official nugot update ? Or will the update just be a normal update that will take me off the beta and on the official nugot.
    02-13-2017 11:11 PM
  2. Sam_Gs7's Avatar
    I'm not enrolled in Beta-Android updates, but at times I've wonder too
    how those members get their official version : This tech article explain
    Link: So you’ve got Nougat through Android Beta: now what? - Android Authority
    02-13-2017 11:58 PM
  3. smalba's Avatar
    That didn't work. It looks like it's for Nexus devices . I'll have to keep looking for Samsung devices .
    02-14-2017 09:13 AM
  4. jamezr's Avatar
    I think you have to go into the Samsung beta apps and de-register. then they send you the stock image for your device.
    Found it!
    10. How can I quit Galaxy beta Program?
    You can cancel through the 'Deregister' menu in the ‘Galaxy Beta Program’ app.
    In order to use the official software and services, be sure to reinstall(rollback) the final version of the official software.
    You can re-install software by using the Smart Switch PC software. Once the software is re-installed, the device will be reset and all data which generated during Galaxy Beta Program will be erased.
    (You can find details from FAQ #11 followed.)
    Also all data which had been backed up before installing beta software can be recovered but data which has been created after installing beta software may have limitation to recover.
    Samsung Service Center also supports re-install the official software.
    Please contact to Call Center, you will be guided to the nearest service center.
    - Call Center : 1-800-726-7864
    http://static.samsungmembers.com/bet...S/faq_sub.html
    02-14-2017 10:42 AM
  5. Sam_Gs7's Avatar
    😏 I said above I'm not into Beta testing..But the process
    to get enrolled and install the official version, must be
    the same in all devices-Powered by Android
    You'll get a notification to install the official version - But
    I could be wrong, so wait for more answers
    While I was typing another member reply to this
    question. Hope jamezr answer works for you
    02-14-2017 10:51 AM
  1. I disagree with the reviews...
    By jtb79 in forum Samsung Gear S3
    Last Post: 02-18-2017, 06:08 PM
  2. Can the heads up notification be disabled on the LG V20?
    Last Post: 02-13-2017, 10:28 PM
  3. Replies: 0
    Last Post: 02-13-2017, 07:27 PM
  4. Replies: 0
    Last Post: 02-13-2017, 07:23 PM
  5. how to properly root asus zenfone max step by steps
    By AC Question in forum ASUS ZenFone Max
    Last Post: 02-13-2017, 07:14 PM
