1. flcod56's Avatar
    How to cut and paste with Samsung Galaxy 7 Edge
    02-15-2017 06:13 PM
  2. B. Diddy's Avatar
    Are you trying to cut and paste text, a file, some element in an image, or something else?
    02-15-2017 09:06 PM
  3. mountainman's Avatar
    If you want to copy text - hold your finger on the word. The Copy box will pop up. You'll also have the ability at that time to select additional words with the selector sliders.
    To paste, hold your finger in the area you want to paste, and the paste option will come up.
    02-15-2017 09:46 PM
  4. hasasimo's Avatar
    You will also have the option to "select all" text before you cut or copy.
    02-15-2017 10:42 PM
