anon(9780053)
Banned
I had it and then was a dummy and tried to go back to mm because I read I would no longer get ota updates. I broke my phone.Haha i been on this Update Nougat for over 2 weeks Firmware QA6!
Yeah I dislike that they took away the quick setting options, but after you get used to the way the new menu is it seems easier to find stuff.Aagh !!
The settings menu was changed.
Just when I thought I had it figured out & could do it in my sleep
No, you can only receive an over-the-air update if you're on an official build (such as APK1).If I side loaded QA4 will I receive QA6 OTA? I haven't so far.
Battery drain was heavy the first hour or two after the upgrade, but seems to be leveling off in a more normal pattern. I think it will take a day or two before it settles down and useful data is available.
You have to Odin back to stock MM APK1If I side loaded QA4 will I receive QA6 OTA? I haven't so far.
Thanks, that's what I was afraid of. Flashing back to a stock ROM is beyond my Android technical skill set.You have to Odin back to stock MM APK1
