A
AC Question
Hi Everybody, I need your help and knowledge on an issue I encountered when I bought my s7 edge last week.
I bought the International version on Amazon for 579$. I get the new phone (box was definitely unopened), I try and turn it on but it does not start. I connect it to the charger and it seems like the battery was at 0%. I charge it to 100% and everything works fine.
Now usually whenever I buy new phones the battery has always some charge in it and the fact that this had none made me worry about a faulty battery.
It's hard for me to understand if the battery is draining to fast or not. The only info I could give you is that now I'm at 86% and the estimated battery life is around 13 h and 58 min. Is this a good parameter? should it be better?
I have the possibility to return it for a refund so then I could buy another one but it's kind of a pain so I would want to do it only if it's really necessary.
What are you guys thoughts on it? any suggestion?
Thanks a lot in advance
