Don't see it there.No I'm in the right one, it's a feature that was on the note 7 , and now available for s7 edge
I found it through Google Now early this morning and installed it. I don't really have anything I want to put into a secured folder but I'll keep the app anyways.
You on Nougat or MM? I ask as I saw something that said you needed Nougat for it to work.
Still don't see it. Guess it's for Nougat only.If you go their website on top right hand corner where it says download apk go to new and follow the link
It is. For Nougat only that is.Still don't see it. Guess it's for Nougat only.
It's not supposed to import your app's previous data when you import the app to the Secure Folder. The idea is that you're installing a fresh, separate version of the app, with its own separate data.I am on at&t and nougat and mine doesn't work. It does not import the data of any imported application.
