1. mustang7757's Avatar
    You can now get the app apk download on sammmobile website and it works
    02-20-2017 09:20 AM
  2. pontiac005's Avatar
    02-20-2017 11:08 AM
  3. mustang7757's Avatar
    No I'm in the right one, it's a feature that was on the note 7 , and now available for s7 edge
    the tall guy and CrisG like this.
    02-20-2017 11:12 AM
  4. jhimmel's Avatar
    Don't see it there.
    02-20-2017 11:24 AM
  5. mustang7757's Avatar
    If you go their website on top right hand corner where it says download apk go to new and follow the link
    02-20-2017 11:53 AM
  6. NexusGirlX's Avatar
    I found it through Google Now early this morning and installed it. I don't really have anything I want to put into a secured folder but I'll keep the app anyways.
    mustang7757 likes this.
    02-20-2017 12:03 PM
  7. sparksd's Avatar
    You on Nougat or MM? I ask as I saw something that said you needed Nougat for it to work.
    02-20-2017 01:08 PM
  8. NexusGirlX's Avatar
    I have Nougat installed.
    02-20-2017 01:12 PM
  9. Gray Area's Avatar
    Good stuff
    02-21-2017 05:29 AM
  10. Gray Area's Avatar
    It works good, thanks for this post. That was 1 of those gn7 features I missed.
    02-22-2017 10:54 AM
  11. mustang7757's Avatar
    Your welcome))
    02-22-2017 11:20 AM
  12. Gary02468's Avatar
    It has now been officially released, so you can install it directly from the Galaxy App Store.
    02-24-2017 08:34 AM
  13. D_Gabe's Avatar
    YAY! I missed my Secure Folder a lot!
    02-24-2017 08:47 AM
  14. jhimmel's Avatar
    Still don't see it. Guess it's for Nougat only.
    02-26-2017 07:08 AM
  15. LineKill's Avatar
    It is. For Nougat only that is.
    02-26-2017 09:11 AM
  16. NexusGirlX's Avatar
    It is Nougat only. If you try to install it on MM, you will get a parse error when you try to install it. I tried.
    jhimmel likes this.
    02-26-2017 10:19 AM
  17. fabris40's Avatar
    I am on at&t and nougat and mine doesn't work. It does not import the data of any imported application.
    Decided to uninstall it.
    02-26-2017 01:22 PM
  18. Gary02468's Avatar
    It's not supposed to import your app's previous data when you import the app to the Secure Folder. The idea is that you're installing a fresh, separate version of the app, with its own separate data.
    Gray Area likes this.
    02-27-2017 09:43 AM
  19. NexusGirlX's Avatar
    This is it exactly.It allows you to have two versions of the same app, one you don't care if anyone sees if you so choose, and one that only you can see.
    02-27-2017 09:46 AM
  20. motorcycle_monkey's Avatar
    I am still on the beta on Verizon, and the secure folder will not install correctly. So, maybe in the summer when I get the official Nougat release it will finally work...
    02-27-2017 09:59 AM
  1. Rooting Gone Wrong on Samsung Note 5?
    Last Post: 02-23-2017, 02:54 PM
  2. My note 4 says its screen lock is password protected but it isnt ...
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 02-22-2017, 08:51 AM
  3. Samsung Note 5 won't boot past the Samsung logo sceen?
    By ex0LL in forum Samsung Galaxy Note 5
    Last Post: 02-21-2017, 05:14 PM
  4. My Samsung Note 5 Won't Turn Off??
    By AC Question in forum Samsung Galaxy Note 5
    Last Post: 02-20-2017, 12:45 PM
  5. Replies: 0
    Last Post: 02-20-2017, 04:57 AM
