1. AC Question's Avatar
    The keyboard comes up instantly, no slag when typing, but sometimes takes 10 seconds to go after typing on messenger, Snapchat etc , I know the phone us powerful enough to run this 100% perfectly so does anyone know how to fix this?
    02-20-2017 04:31 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Does this happen in Safe Mode as well? You'll only be able to test it out on preinstalled apps in Safe Mode, though. https://support.t-mobile.com/docs/DOC-28008
    02-20-2017 05:30 PM
  3. chanchan05's Avatar
    Is this the preinstalled keyboard?
    02-20-2017 05:46 PM
  4. IAmSixNine's Avatar
    I know a while back Swiftkey had an issue which you described, and i had it happen to me as well last night.
    02-21-2017 08:38 AM
  5. o4liberty's Avatar
    Just downloaded 7.0 and my keyboards are just as quick if not quicker.
    02-21-2017 11:03 AM
  6. Leoelkins1's Avatar
    Yes stock Samsung keyboard
    02-21-2017 04:04 PM
  7. Leoelkins1's Avatar
    It actually seems to have got slower recently with 7.0 which is annoying for me
    02-21-2017 04:05 PM
  8. Leoelkins1's Avatar
    Can u explain to me why I would need to put it in safe mode?
    02-21-2017 04:06 PM
  9. chanchan05's Avatar
    Safe mode will stop all other non stock apps from running when you start. This will eliminate the possibility if a downloaded app is interfering with the keyboard.
    B. Diddy likes this.
    02-21-2017 06:47 PM
  10. Leoelkins1's Avatar
    Thanks that helps, I've found it seems to be coming from Facebook messenger, I've contacted them.
    02-22-2017 02:01 PM
  1. Cast to a nearby device pop up on HTC 10 (7.0)
    By AC Question in forum HTC 10
    Last Post: 02-20-2017, 04:38 PM
  2. How do I reset my daily steps to zero on S Health?
    Last Post: 02-20-2017, 04:21 PM
  3. Cast to a nearby device pop up on HTC 10 (7.0)
    Last Post: 02-20-2017, 04:05 PM
  4. Replies: 0
    Last Post: 02-20-2017, 04:01 PM
  5. Replies: 0
