1. mushie143's Avatar
    Hi - I went into my Package Disabler Pro app and get a "license activation error" message. I have tried to reach the company but can't get any help.
    I am not in power save mode, my phone is not rooted, I have already tried rebooting. I do have apps that are disabled through PDP.
    My questions are:
    1- Can I uninstall without re-enabling the apps I have disabled? Or will that screw up my phone?
    2- Should I do the update that is available? even without re-enabling my disabled apps?
    Any help is appreciated :-)
    Package Disabler Pro License Activation Error Message-package-disabler-pro-license-activation-error-message.jpgPackage Disabler Pro License Activation Error Message-package-disabler-pro-license-activation-error-messageb.jpg
    02-21-2017 07:50 AM
  2. ScottsoNJ's Avatar
    Try going on a computer to the Play store and than click on my apps and try to load it that way
    02-21-2017 08:55 AM
  3. trucksmoveamerica#AC's Avatar
    Is this the app everyone uses to stop the OS updates without rooting?
    02-21-2017 09:10 AM
  4. fabris40's Avatar
    I am with at&t and was having exacly the same problem. After several attempts I finally decided to uninstall the app
    02-21-2017 03:29 PM
  5. mushie143's Avatar
    I went into the play store & it does not even show PDP as one of my apps. Any thoughts on why that would be? I definitely have it on my phone.
    02-21-2017 04:09 PM
  6. mushie143's Avatar
    Did you already have apps that were disabled through PDP when you uninstalled?
    02-21-2017 04:11 PM
  7. joe_fresh's Avatar
    No it disables carrier packages and unwanted apps like amazon
    02-21-2017 04:40 PM
  8. underway99's Avatar
    Yes. Well, sort of. Disable COM.SAMSUNG.SDM to block OTA system updates. The problem is that you have to find an old version of the Package Disabler Pro. They updated it after people used it to keep their Note 7s running after Samsung started pushing the Note 7 killer update. The PDP update removed the ability to stop OS updates.
    So, you can use an old version of PDP to stop updates, but not the one currently in the Play store.
    02-21-2017 05:46 PM
  9. fabris40's Avatar
    No, I started right after I installed Nougat.
    02-22-2017 11:05 AM
  10. chowming26's Avatar
    I had same exact problem it looks like once nougat update it no longer functions. All references on the dev site are for the 7.7 version. So i really need this for my version note5 having no root.
    So.. i repaid for the update.
    https://www.google.com/url?sa=t&sour...R5nKFkoMEIm3uQ
    04-22-2017 07:44 PM
  11. chowming26's Avatar
    Here's my current version disable packages o on my m note5
    https://mega.nz/#!J5IVHIiI!UHNdhlwp1...w8dWKir46rCeQQ
    It's an .xml exported from the 7.7 version
    04-22-2017 07:53 PM
  12. chowming26's Avatar
    Thank you i missed com.samsung.sdm.
    I wish i had known before the nougat update but all is well. I added it to disabled.
    After i posted my xml export.
    04-22-2017 08:01 PM
  13. underway99's Avatar
    If you're not aware, they released an update for PDP a few days ago that restored the ability to disable COM.SAMSUNG.SDM.
    Package Disabler Pro License Activation Error Message-screenshot_20170422-201522.jpg
    chowming26 likes this.
    04-22-2017 08:12 PM
  1. Error 504 while installing app
    By Karan Kalia in forum ASUS ZenFone 2
    Last Post: 09-04-2017, 08:07 AM
  2. Mybackup pro
    By ekendraed in forum Samsung Galaxy S7 edge
    Last Post: 02-22-2017, 06:52 PM
  3. Where are messages stored in Messaging?
    Last Post: 02-21-2017, 02:57 PM
  4. lg pro lite software problems
    By izabdi in forum Ask a Question
    Last Post: 02-21-2017, 02:49 AM
  5. Replies: 1
    Last Post: 02-20-2017, 10:42 PM
