08-12-2018 11:55 PM
29 12
tools
  1. Est_XCIV's Avatar
    YouTube videos max out at 720p, and don't look as good however
    02-23-2017 03:49 PM
  2. jasonandrews25788's Avatar
    it has been always my advice to to everyone as you'll never notice the difference and it'll add extra battery life.
    has anyone here been able to notice the difference?
    02-26-2017 07:16 PM
  3. speccy's Avatar
    I can't see this making much difference to battery life. Maybe if you play games a lot, it might, but in normal use, it still has to light all the non-black pixels to create the image, so if you have something of a size of 1 pixel that needs displaying, the same image at a lower resolution will take use 4 pixels (at the lower resolution), this isn't to say that a lower resolution uses more pixels and is therefore worse for the battery, because it isn't, but the difference for non-gaming use would be minimal at best.
    03-01-2017 02:05 AM
  4. Shironekomaru69's Avatar
    The screen still looks vibrant and beautiful, and I seemed to have added 2 hours on screen time to my battery life. This is awesome!
    Aparently, changing resolution doesn't make battery life longer. And it's a fact, BUT changing it lower than the original will boost performance especially to those apps that renders amazing graphics. If you are not a fan of high quality graphics and just wants a performance boost, changing res is a good idea.
    08-12-2018 11:55 PM
29 12
  1. Replies: 1
    Last Post: 02-22-2017, 12:20 AM
  2. Replies: 1
    Last Post: 02-21-2017, 02:13 PM
  3. My phone is an Samsung Galaxy S5 G900F. I installed the correct root file and the correct twpr recov
    By Mikey Is Here12 in forum Samsung Galaxy S5 Rooting, ROMs & Hacks
    Last Post: 02-21-2017, 01:47 PM
  4. why is my android device is on fire?
    Last Post: 02-21-2017, 08:36 AM
  5. how to identify software version for dead lenovo sets?
    Last Post: 02-21-2017, 08:17 AM
