08-13-2018 12:55 AM
29 12
tools
  1. ThrottleJohnny's Avatar
    The screen still looks vibrant and beautiful, and I seemed to have added 2 hours on screen time to my battery life. This is awesome!
    02-21-2017 09:33 AM
  2. Jaycemiskel's Avatar
    Yeah, I've switched mine to 720p and I still like the way it looks. My battery life is so much better!
    dm3ready and KPMcClave like this.
    02-21-2017 10:29 AM
  3. soldier45's Avatar
    No way I go backwards in res for anything.
    mountainman likes this.
    02-21-2017 06:21 PM
  4. ThrottleJohnny's Avatar
    Why?
    02-21-2017 06:28 PM
  5. popkurn611's Avatar
    Shouldn't have to downgrade your phone's best capabilities to preserve battery life.
    When I tested the QHD vs FHD, I noticed zero difference in battery life
    lammy8 and Tsepz_GP like this.
    02-21-2017 07:02 PM
  6. ThrottleJohnny's Avatar
    Except its not a downgrade. Plenty of 1080p phones have gorgeous screens, and this one is no different. And I didn't have to do it. I chose to. The added screen time was surprising and welcome.
    KPMcClave likes this.
    02-21-2017 08:55 PM
  7. popkurn611's Avatar
    Except its not a downgrade. Plenty of 1080p phones have gorgeous screens, and this one is no different. And I didn't have to do it. I chose to. The added screen time was surprisingly and welcome.
    I will say to the naked eye you can't tell the difference, but changing it to 720p is downright silly.
    See and I saw zero difference in screen time.
    02-21-2017 08:57 PM
  8. ThrottleJohnny's Avatar
    I saw it right away. I wonder if anyone else has noticed it. At least you did try it so there was some curiosity there. lol
    02-21-2017 08:58 PM
  9. lammy8's Avatar
    Same here. Sammy's battery stats says it gives me an extra 20mins battery apparently, 0 noticeable difference to SOT mind
    02-21-2017 10:24 PM
  10. dcmarch's Avatar
    How do you change resolution
    02-21-2017 11:07 PM
  11. Almeuit's Avatar
    Settings and then display. Within there you should see the option.
    02-21-2017 11:21 PM
  12. talberry's Avatar
    I dont have an option to change resolution. Hmm
    ToddK likes this.
    02-22-2017 03:06 AM
  13. LineKill's Avatar
    You have to be on Nougat.
    pankaj981 and Toes Up like this.
    02-22-2017 03:18 AM
  14. anon(5630457)'s Avatar
    Now you know why I get amazing battery life on my 7 Plus! I'd rather have 1080p resolution and amazing battery life than 2K and so-so battery life.
    02-22-2017 07:23 PM
  15. Jaycemiskel's Avatar
    I mostly look at text on my phone, I can't tell a big enough difference to stay on 2k. I'm on the nougat beta and can't use my gear vr until I'm on official because Verizon stopped the beta so I have nothing to make me use a higher screen resolution. As long as you use the smallest DPI settings, you can continue to see everything on the screen.
    02-22-2017 08:05 PM
  16. Wizzy's Avatar
    What's a 7 plus?
    02-22-2017 09:54 PM
  17. Tsepz_GP's Avatar
    Exactly.
    It makes zero difference, the Estimate is useless as it's all down to how you use the phone that day.
    Mine is set to WQHD. Why downgrade my display to get no benefit?
    I also noticed that in 1080P text in apps like WhatsApp look a bit jagged and thick, not smooth as they are in WQHD.
    02-22-2017 11:19 PM
  18. Tsepz_GP's Avatar
    I get amazing battery life on WQHD in my S7 Edge, over 6h SOT consistently.
    I'd never go back to a 1080P phone, I left that 3years ago in my Galaxy S4.
    02-22-2017 11:22 PM
  19. Almeuit's Avatar
    What's a 7 plus?
    She means iPhone 7 Plus.
    02-23-2017 12:06 AM
  20. ThrottleJohnny's Avatar
    Exactly.
    Except I use my phone the same way now as I always have. Going to 1080p has extended my battery life by quite a bit.
    In no way is anybody saying anyone else has to follow suit. I'm giving my experience in case others are interested, or have done so and noticed something similar.
    02-23-2017 01:05 AM
  21. speccy's Avatar
    I prefer to maximize the amount of text on the screen, so the higher the resolution the better for me.
    02-23-2017 04:57 AM
  22. D13H4RD2L1V3's Avatar
    Well, if you're eager for more battery, there's an app that shuts off some extra pixels.
    I personally just use it to dim the screen at night, but if you really do need some extra power, it *might* help.
    https://forums.androidcentral.com/e?...token=Mqah52MD
    02-23-2017 07:18 AM
  23. anon(5630457)'s Avatar
    To each his/her own. I don't miss the QHD display. Sure, it was visually appealing, but it wasn't necessary.
    02-23-2017 09:34 AM
  24. meyerweb#CB's Avatar
    Even if you can't see the difference without a magnifying glass?
    02-23-2017 10:07 AM
  25. Jaycemiskel's Avatar
    There's no difference in the amount of text on the screen like there used to be. That setting is separate from the resolution setting. That's why I use it, otherwise I would stay on 2k.
    02-23-2017 11:56 AM
29 12
  1. Replies: 1
    Last Post: 02-22-2017, 01:20 AM
  2. Replies: 1
    Last Post: 02-21-2017, 03:13 PM
  3. Replies: 1
    Last Post: 02-21-2017, 02:47 PM
  4. why is my android device is on fire?
    Last Post: 02-21-2017, 09:36 AM
  5. how to identify software version for dead lenovo sets?
    Last Post: 02-21-2017, 09:17 AM
