1. Lyrad9's Avatar
    Yesterday my phone updated and now I no longer receive LED notifications when an email or text comes in. I have checked LED notifications and the slider is on. I have restarted many times and still nothing. I tried turning notifications on and off and back on and still nothing.
    02-21-2017 02:22 PM
  2. SpookDroid's Avatar
    Is that happening with any other apps or just the e-mail/text ones? Any carrier in particular? I just updated mine (T-Mobile) and have had no issues, BUT I don't use the stock apps (I use Nine for e-mail, Textra for texts).
    02-21-2017 02:26 PM
  3. Lyrad9's Avatar
    I'm on AT&T. Everything else is fine its just email and text. I am using stock apps. Is that a problem?
    02-21-2017 02:43 PM
  4. SpookDroid's Avatar
    Shouldn't be... but try using a different app for texts, for instance. If the problem is just with the stock apps, then at least we narrow down the problem to those apps. Have you tried turning those notifications on/off too?
    02-21-2017 03:31 PM
  5. justin1578's Avatar
    Clear the cache, soft reset, try safe mode. Clear the cache partition.
    If all else fails backup and reset. Sorry you are having issues.
    02-21-2017 04:46 PM
  6. Lyrad9's Avatar
    Switched to Textra and still no LED notification. Switched the individual apps switch on and off with no luck.
    02-21-2017 04:46 PM
  7. SpookDroid's Avatar
    I'd try the cache clear mentioned above... I just tried mine with the stock text app and have no issues with LED lights (but again, my phone is running T-Mobile's ROM). Do you have any apps that could be interfering with LED behavior? Try Safe Mode. Does the problem persist there?
    02-21-2017 05:08 PM
  8. Lyrad9's Avatar
    cleared the cache and now I am receiving notifications for text but still no email.
    02-21-2017 05:14 PM
  1. What is this notification symbol?
    By Samsung G5 Chicago in forum Ask a Question
    Last Post: 02-22-2017, 06:31 PM
  2. Replies: 1
    Last Post: 02-21-2017, 03:45 PM
  3. Replies: 1
    Last Post: 02-21-2017, 02:51 PM
  4. My phone is showing European time after a trip
    Last Post: 02-21-2017, 02:48 PM
  5. Replies: 0
    Last Post: 02-21-2017, 12:41 PM
