1. xoomer1's Avatar
    nougat is now downloading on my 8yr old sons old droid turbo 2...cant believe moto got it before the S7
    smooches680 and lizardchest like this.
    02-22-2017 04:03 PM
  2. SpookDroid's Avatar
    Is yours any carrier in particular? The S7 Edge (unlocked) has been rolling out for a while, and most US carriers are rolling out theirs. If you're like me and hate pop-up notifications, ge ready to despise the Nougat update on the S7 Edge. Yes, it's speedier and battery does seem to last longer... but now there's no way to disable that (insert VERY foul language here) feature like you could before; now you have to disable the notification's sound and vibration too if you want to get rid of the intrusive pop up.
    02-22-2017 04:52 PM
  3. joe_fresh's Avatar
    My Z force does not have the pop up notification, still waiting for my s7 edge to get it
    02-22-2017 05:27 PM
  4. Fit24's Avatar
    Which phone carrier? My AT&T S7 Edge was updated a few days ago.
    02-22-2017 05:51 PM
  5. IAmSixNine's Avatar
    My s7 edge got updated Friday the 17th. At this point you should probably place blame on your carrier and not Samsung.
    Although my TMO HTC 10 had it months before my TMO s7 edee. That would be a Samsung issue.
    02-23-2017 10:59 AM
  6. Alanhd's Avatar
    I have the XEU unlocked uk edition which hasn't got it, yet some carriers editions have so I lay the blame on Samsung.
    02-23-2017 02:03 PM
  7. IAmSixNine's Avatar
    In the case of the unlocked samsung version yeah i guess you can blame them since there is no carrier delay.
    Alanhd likes this.
    02-23-2017 02:12 PM
  8. xoomer1's Avatar
    yes its verizon
    02-23-2017 04:52 PM
  9. anon(5719825)'s Avatar
    The US unlocked Edge doesn't have Nougat yet either.
    02-23-2017 05:47 PM
  10. D13H4RD2L1V3's Avatar
    If it helps ease the pain, I have zero update notifications on my unlocked Moto Z.
    That could be due to me flashing the Nougat firmware myself but I'm running on an older build and I have zero notifications for a newer build.
    It's also rooted with a custom recovery, but as far as I know, rooting and a custom recovery don't stop your device from receiving OTA updates, but will cause it to fail when trying to install said update.
    02-24-2017 10:23 AM
  1. When is Verizon note 5 getting nougat?
    By owensch1 in forum Samsung Galaxy Note 5
    Last Post: 04-16-2017, 03:35 AM
  2. where the hell is Nougat???
    By seeyaiphone71 in forum Samsung Galaxy S7
    Last Post: 02-28-2017, 08:05 AM
  3. LG G4 Nougat
    By Joshua Luther2 in forum Android 7.0 Nougat
    Last Post: 02-22-2017, 04:44 PM
  4. Replies: 0
    Last Post: 02-22-2017, 03:52 PM
  5. Motorola android 4glte deleting downloads
    Last Post: 02-22-2017, 11:39 AM
