1. AC Question's Avatar
    I know this is a weird question, But I have a refurbished s7 edge that was made in september, I just wanna know has anyone elses phone lasted this long, hopefully that will give me a reference point for the life I can get out of mine.
    02-24-2017 11:49 AM
  2. belodion's Avatar
    Without knowing anything about the device, I speculate that it can be expected to be good for several years. But I'll move this to the S7e forum to see what those guys have to say.
    shohel rana2 likes this.
    02-24-2017 11:56 AM
  3. bandofbrothers2112's Avatar
    I bought mine September 2016.
    02-24-2017 11:57 AM
  4. 1naturalace's Avatar
    I've had my s7 since march and its worked really well the whole time
    02-24-2017 12:07 PM
  5. skinneejay's Avatar
    I have had mine since launch. The phone still works flawless. I do my normal wipe when new updates come out.
    The best phone I've owned.
    02-24-2017 02:11 PM
  6. abcomputin's Avatar
    Same for me!
    02-24-2017 02:16 PM
  7. Jason Fournier1's Avatar
    Since March. Still like new except battery not as good. I think that is due to Android though. Probably time for a reset and fresh install
    02-24-2017 02:32 PM
  8. jbjtkbw007's Avatar
    Last week of March 2016. Have only done 1 factory reset to fix Samsung Pay. Now, I have the dreaded vertical pink line and have to send to Best Buy to have it serviced locally.
    02-24-2017 02:34 PM
  9. Jeremy MacMull's Avatar
    Yep and it still works really well. Excellent battery life. I'm looking forward to the nougat update.
    02-24-2017 03:22 PM
  10. tcdude's Avatar
    I'm on my second S7E because of the pink line going through the screen issue and ironically my second one now has the same issue
    02-24-2017 04:17 PM
  11. Fred Henk's Avatar
    Had mine since June 2016. Not a single problem.
    02-24-2017 04:40 PM
  12. trsbbs's Avatar
    Replaced twice. Sent in for repair once. Now the pink line has appeared again. Third phone on it's way.
    NOTE. Never damaged. Never abused. In a case as well.
    02-25-2017 12:36 AM
  13. iWEARaONESIE's Avatar
    Had mine since the 1st day it came out. I've had zero issues with it. I did however drop it and crack the screen and had to send it to Samsung to have the glass replaced.
    02-25-2017 01:04 AM
  14. anon(5719825)'s Avatar
    I bought two on launch and have one of them in excellent condition. The other has a cracked display. I tripped on some stairs on Christmas Eve and cracked the glass in the bottom left corner. It still works though.
    Is there anyone that has had their original s7 edge since it came out last march?-20170225_005052.jpg
    02-25-2017 01:55 AM
  15. Alanhd's Avatar
    I've had mine since launch, it's still spotless and no lag at all, battery life is subjective because I do use it a lot, but saying that this will be my last Samsung phone due to the poor way Samsung has handled the nougat update. I'm hoping they put aSd card in the pixel 2
    02-25-2017 02:34 AM
  16. ded1945's Avatar
    Had mine since launch with no issues, cracks or problems!
    02-25-2017 07:43 AM
  17. ZOMMBIE1's Avatar
    Have an S7 edge since launch. Still working just fine. Even gave my 7 yr old daughter an S6 edge from launch that still runs like a champ.
    02-25-2017 08:26 AM
  18. smooches680's Avatar
    Yes I've had mine since it first came out. And it's the original one.
    02-25-2017 08:52 AM
  19. lammy8's Avatar
    Since day of release, I've cracked the screen a little in the top right corner (was in a case at the time too) and have screen burn in. Otherwise ok.
    02-25-2017 11:19 AM
  20. Rumblee1's Avatar
    Bought mine from Verizon on launch. It lasted a month. Had serious data connection issues. They tried everything. No luck so they had me take it into a verizon store to swap it out. They wouldn't give me a brand new unit. I explained that I had it only 4 weeks, and paid cash for it. No luck. So I took it to be repaired, sold it and bought another brand new one. It's been great. However, being an audiophile, I bought a ZTE axon 7 on launch. Your going to think I'm crazy, but it's a better phone all around. It's faster, has 64gb of built in storage plus micro sd, a beautiful superamoled screen, longer battery life, and don't forget the hifi dacs and dolby atmos . I love it. Now I'm not knocking the S7 edge, I'm just saying that I'll never buy from a carrier again.
    02-25-2017 05:06 PM
  21. hasasimo's Avatar
    Got mine in February of 2016 (launch day). It's been terrific, but just sold it because I wanted the 128GB black pearl version.
    02-25-2017 06:08 PM
  22. bandofbrothers2112's Avatar
    In the U.K. if the phone is under 6 months of age then they are allowed one repair and if that fails a new phone has to be supplied as its assumed by U.K. Law that the fault was more than likely evident at the time of purchase.
    My phone developed the Pink Line problem 4 months in and the shops authorised engineer swapped out the screen.
    02-26-2017 12:08 AM
  1. Bluetooth turns off when phone power is off
    Last Post: 03-01-2017, 09:01 AM
  2. I accidentally formatted my gs6 edge, can I recover data?
    By Kukuraai in forum Android 6.0 Marshmallow
    Last Post: 02-24-2017, 01:14 PM
  3. Replies: 1
    Last Post: 02-24-2017, 11:48 AM
  4. Why is my call history not showimg up
    Last Post: 02-24-2017, 11:22 AM
  5. Replies: 0
    Last Post: 02-24-2017, 10:56 AM
