09-13-2017 03:19 AM
36 12
tools
  1. SurfnSun's Avatar
    I plug it in and the fast charging turns itself off. You can't turn it on while the phone is charging. Unplug and the toggle flips back to the on position. Not happy about this at all!
    Any ideas?
    02-24-2017 10:52 PM
  2. Tim1954's Avatar
    Do you have the original charger and cable?
    02-25-2017 04:07 AM
  3. amyf27's Avatar
    Hmm. I just did the Nougat update last night around 7 pm. My fast charging is working fine.
    02-25-2017 05:46 AM
  4. amyf27's Avatar
    Ant other issues after Nougat ?
    02-25-2017 06:25 AM
  5. sydneycooper1979's Avatar
    Sometimes a factory reset will clear out any bugs after a major update. I know they are a pain, but it may help.
    SurfnSun likes this.
    02-25-2017 08:34 AM
  6. ToddK's Avatar
    I upgraded to Nougat a few days ago.... Fast charging still working fine here...
    02-25-2017 09:53 AM
  7. SurfnSun's Avatar
    Yep still using all oem equipment. When I get home later I'll take a video of the toggle moving back and forth when I plug the phone in.
    Btw it takes an eternity to change this battery on regular charge...it was near dead when I went to bed last night and calc'ed the charge at almost 8 hours lol
    02-25-2017 11:20 AM
  8. Gary_Berg's Avatar
    You might try a different cable; they can go bad...
    02-25-2017 01:48 PM
  9. IAmSixNine's Avatar
    Is the phone hot/warm when its charging over night?
    If it takes that long your either not charging it with enough power or the phone is consuming to much power while its charging.
    02-25-2017 03:47 PM
  10. SurfnSun's Avatar
    Fast charging is back! I don't know why. The toggle still moves over but the lock screen says fast charge.
    Btw my battery life is killing it on nougat!
    sydneycooper1979 likes this.
    02-26-2017 01:17 PM
  11. Bhawks_2's Avatar
    I've tried that. Doesn't solve the problem. Exactly the same symptoms here: last week on Android 6 the phone would charge from 0 - 100 in about 2 1/2 hours. Now it takes 4+ hours to get from 40% to full. Very annoying. Anyone have any tips?
    Fast charging is enabled in the system settings for me by the way. Makes no difference
    KR
    Stefan
    KatieBlue likes this.
    03-04-2017 09:51 AM
  12. pontiac005's Avatar
    Try another charger and cable?
    03-04-2017 01:47 PM
  13. maaron101's Avatar
    Having the same issue. Fast charging stopped working after the Nougat update. Toggle is on, I've tried multiple OEM adaptive chargers and different cables, factory reset and wiped the cache. Nada. Sam tech is useless too.
    03-07-2017 11:37 PM
  14. JesperKA's Avatar
    Seeing exactly the same; SGS7 Edge on Nougat.
    Extreme charge time; full 24 hours for 0 - 100% and fast charging toggles off and back on when I insert original charger and cable. Recharges so slow that when browsing while charging, the net charge is negative (drains).
    Cache wipe did not solve anything.
    However when full charge is reached the drain seem slightly less in Nougat
    Good for you SurfnSun that the problem disappeared,
    pitty we don't know how?
    Did anyone else see the same issue and solved it?
    03-13-2017 08:03 AM
  15. mushie143's Avatar
    I just did the Nougat update and no longer have the Fast Charging option in my settings. Where can I find it?
    03-19-2017 07:22 PM
  16. LineKill's Avatar
    I just left the answer for you in the other thread😊
    03-19-2017 07:41 PM
  17. mushie143's Avatar
    Got it - Thanks :-)
    LineKill likes this.
    03-19-2017 07:48 PM
  18. mushie143's Avatar
    Got it - Thanks :-)
    03-19-2017 07:48 PM
  19. ChristoNewzo's Avatar
    After Butt Nougat my Note 5 fast charging sometimes works sometimes doesn't. When it doesn't work it says 6 hours until battery full, when working its less than 2 hours.
    Factory cable, and I have two of them. Both same issue.
    One time I unplugged the cable and turned fast charging off and back on and then it fast charged. But that bandaid doesn't work everytime.
    Kontos likes this.
    04-12-2017 10:38 PM
  20. Gerald Acker's Avatar
    Any luck with a solution. My Note 5 is doing the exact same thing except I can't even it get it to fast charge by turning it on and off. I did a factory reset but that hasn't helped.
    Kontos likes this.
    04-16-2017 07:05 PM
  21. pteezay's Avatar
    Same issue with fast charging not working after update. Worked flawlessly for 1.5 years and all the sudden today it decides to not work. Did everything but a hard reset however it seems that doesn't solve the issue. I hope they figure out a solution soon.
    Kontos likes this.
    04-29-2017 02:27 PM
  22. Kontos's Avatar
    I'm having issues as well. I plugged it in this afternoon around 45% and 4 hours later it's at 85%
    It's been slower the last few days but today was a whole different level of slow. I did the Nougat update last month sometime though and have not downloaded any new apps since. Not sure what to do right now as I have it turned off and plugged in to see if that helps.
    04-29-2017 08:42 PM
  23. blueGN7's Avatar
    My fast charge is broken since 7.0. takes hours to charge from 60-100%. in the past when pull down menu, can touch to see how long to fast charge & it was fairly accurate. maybe charged a bit faster than stated. So If it said full charge in 35 min it may actually be 33 min. Now it will say charge in 47 min & takes hours.
    I use Samsung fast charger & cable that came with phone. No, my charger &/or cable did not mysteriously break the day after the 7.0 update. I also dislike the look/feel of the 7.0. Much harder to see icons, text. Edge screen contacts now all look the same, lost the different colors. Light blue tiny icons against white background. When tap a contact to make call, get TINY icons to choose between text/call, why?
    Wish I never updated.
    Kontos likes this.
    04-30-2017 09:05 PM
  24. bunnyBugsLife's Avatar
    i've the same problem. Im just updated my note 5 to Nougat and suddenly mu fast charging is not working. Can somebody help me.
    thank you.
    05-07-2017 11:25 PM
  25. Sebastienbaro's Avatar
    Try plugging it into an outlet with no other things plugged in it.. mine was not working for some reason, turned out i was plugging it in the same outlet as a lamp and that was disabling my fast charging.
    05-10-2017 09:18 PM
36 12
  1. How to fix fast charging?
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 03-02-2017, 03:18 PM
  2. Htc 10 stuck in bootloop after restart
    By Megaton_Reaper in forum HTC 10
    Last Post: 02-26-2017, 03:01 PM
  3. Replies: 1
    Last Post: 02-24-2017, 10:10 PM
  4. How to fix fast charging?
    Last Post: 02-24-2017, 07:44 PM
