1. remokat's Avatar
    Today my S7Edge started to work strange. It was restarting itself few times, some system process stopped working so I decided to instal again system through Odin. I already had the same install files which works earlier. I did everything with 4 files and pit file, odin says that it passed and then my phone start to show blue background with dead robot and "no command" sign. Restarting phone doesn' fix it. I tried to instal system again but it's all the time the same for me...I can enter to the recovery menu and I tried to wipe data/factory reset and cache partition - nothing workd. Actually I tried to instal system again 5 times and still getting no command error...nothing I can do...please help me...
    02-26-2017 02:18 PM
  2. Younes Cheikh's Avatar
    Hi Did you solve you problem? I'm having the same issue since this morning
    04-10-2017 04:19 AM
  3. mnc76's Avatar
    This is appears to be becoming a com non in issue.
    I'm also getting this BSOD issue after the Nougat update.
    Requires multiple hard reboots just to get the screen to work again.
    This is after a factory reset.
    04-17-2017 04:04 AM
  1. Android 7 arrived today: S7 Edge on AT&T
    By azdenn in forum Samsung Galaxy S7 edge
    Last Post: 03-22-2017, 07:45 AM
  2. Replies: 2
    Last Post: 03-20-2017, 04:50 PM
  3. battery on Samsung S7 edge
    By AC Question in forum Samsung Galaxy S7 edge
    Last Post: 02-27-2017, 09:17 PM
  4. delete samsung pay from phone
    By AC Question in forum Samsung Galaxy S7 Active
    Last Post: 02-26-2017, 11:13 PM
  5. How to access my iCloud email on Android zte max pro phone
    Last Post: 02-26-2017, 03:01 PM
