1. Texas765's Avatar
    S7 edge and doesn't seem as long as used to be
    Just had it fixed for anther problem and they also checked the battery too. Anything on my Screenshots look weird?
    How long should I get using it constantly?
    Attached Thumbnails Battery drain-screenshot_20170226-202852.jpg   Battery drain-screenshot_20170226-202847.jpg
    02-26-2017 02:31 PM
  2. Who884l5's Avatar
    Doesnt look like it was cjarged to 100%. Twitter is possibly not letting the phone sleep too. Social media apps can kill a phone. Maybe disable notifications for it and see where that takes you. Or get rid of it.
    02-26-2017 06:16 PM
  3. talberry's Avatar
    My top 3 battery draining apps (other than Screen) are android OS, android system and Google services.
    Anyone has anyway to reduce the battery consumption in these 3 without compromising the user experience?
    Thanks in advance!
    02-26-2017 06:39 PM
  4. Hey I Tried's Avatar
    Screen and Android OS are basically are your phone. So any changes to those core systems will drastically slow your phone down, or make it unusable.
    Android System is comprised of a huge list of programs, usually system applications. Pressing in Android System will show you just how many different programs are included in that percentage. (And, unless you know what you're doing, messing / disabling those apps can actually cause your phone to become unusable)
    Screens are usually the biggest power hogs on phones. Turn on automatic brightness, turn off Always On Display, lower your screen timeout, and Enable Keep Screen Turned Off.
    02-26-2017 06:53 PM
  1. Savee Battery Saver FREE!
    By Savee in forum Android Apps
    Last Post: 03-24-2017, 01:49 AM
  2. Secure folder causing battery drain
    By Cakefish in forum Samsung Galaxy S7
    Last Post: 03-10-2017, 01:22 PM
  3. battery on Samsung S7 edge
    By AC Question in forum Samsung Galaxy S7 edge
    Last Post: 02-27-2017, 09:17 PM
  4. battery on Samsung S7 edge
    Last Post: 02-26-2017, 12:39 PM
  5. The perfect battery stats
    By sweetypie31 in forum Samsung Galaxy S7 edge
    Last Post: 02-25-2017, 09:50 PM
