1. AC Question's Avatar
    I have an s7 edge and I've tried 3 different times to move my photo files and 3 different times to move the music files. Each time it says they're moved. I go into storage and it says that the SD card has so many gbs used and so many remaining. The device storage is lower also. Then when I go back into my files and check the SD card the files no longer are in the SD card. Then I check my files and half to 75 percent of files (music and or photos ) are missing from my device. Then I have to do the mobile transfer from my old device to my new device in order to recover the files.
    02-27-2017 10:03 AM
  2. IAmSixNine's Avatar
    How are you transferring your files?
    02-27-2017 03:37 PM
  3. pontiac005's Avatar
    Maybe SD card not formatted properly?
    02-27-2017 09:32 PM
  1. Replies: 3
    Last Post: 02-27-2017, 12:33 PM
  2. How to fix text message display?
    Last Post: 02-27-2017, 09:59 AM
  3. How to uninstall the system update which is already installed
    Last Post: 02-27-2017, 09:47 AM
  4. How to know what a 'quality' charging cable or OTG cable is.
    Last Post: 02-27-2017, 09:30 AM
  5. How to stop gmail alerts on my Android phone
    Last Post: 02-27-2017, 08:47 AM
