1. Mattressguy's Avatar
    Anyone know how to get the tabs for people edge notifications to appear again? It's really the only edge feature I cared for. I knew my top 5 contacts had messaged me by the color tabs on the side.
    02-27-2017 11:56 AM
  2. meyerweb#CB's Avatar
    Is this Samsung's "OnCircle" feature? They've been saying for months that service is going away. If it's not that, then I have no idea.
    02-27-2017 01:41 PM
  3. Mattressguy's Avatar
    I'm not sure if that was part of Samsung's on circle or not. When I swipe over to people edge the option is there to call or message one of the contacts.
    02-27-2017 05:39 PM
  4. lokizef's Avatar
    Same issue. People Edge notification tab/strip gone after Nougat update. Already contacted Samsung support. Two days now that I have been waiting for feedback.
    03-02-2017 09:30 PM
  5. lokizef's Avatar
    Same issue. People Edge notification tab/strip gone after Nougat update. Already contacted Samsung support. Said they don't have enough information on this issue and that they needed to escalate to Tech monkeys at Google for resolution.
    Been two days now that I am waiting for an update.
    03-02-2017 09:34 PM
  6. msndrstood's Avatar
    Mine is still there, maybe because I downloaded the app from the Play Store? I don't know, but it's still there.
    03-03-2017 08:33 AM
  7. staticK78's Avatar
    The developer sent out a notice last fall that the people edge feature was being discontinued for some compliance reason. It may not be baked into the nougat software.
    03-03-2017 09:24 AM
  8. ceizeley's Avatar
    That is so sad. I really like it.
    03-10-2017 01:00 PM
  9. scrondar's Avatar
    Heh, the one edge feature I use, and they dump it. Well, that alone may keep me on Marshmallow, at least for now.
    03-10-2017 01:16 PM
  10. scrondar's Avatar
    Which app on the Play Store? I see one called "People Edge S7", but the publisher's name put me off right away.
    03-10-2017 01:20 PM
  11. PJRed2008's Avatar
    Edge strips are on Galaxy Apps not the Play store. I still have mine after nougat, but poster above is correct, support has been dropped.
    03-10-2017 02:25 PM
  12. piannetta's Avatar
    I updated last night and it seems to be still working for me
    03-11-2017 02:05 PM
  13. Alanhd's Avatar
    reading this made me realise that edge feeds had stopped working after the update, luckily toggling it off and on fixed it for me.
    03-11-2017 04:26 PM
  1. Can I update my s7 to nougat?
    By AC Question in forum Samsung Galaxy S7
    Last Post: 02-27-2017, 05:31 PM
  2. Quick Settings on the Notification bar is gone
    Last Post: 02-27-2017, 02:00 PM
  3. Replies: 0
    Last Post: 02-27-2017, 11:15 AM
