1. Nodnerb's Avatar
    Ok, so I've been reading about how stock android messages is changing to "android messages". Today I had the update and am trying it out. However, there are no AOD notifications with the app. Does anyone know if it is possible to get the notifications for this app? If not I'll just go back to the "old" android default "messages" app.
    02-28-2017 12:13 PM
  2. DukeSilversJazz's Avatar
    Stock Messaging that comes with the Samsung device isn't changing names, Google Messenger has changed to Android Messages.
    Make sure notifications for it are turned on in Settings - Notifications, then that AOD is set to read notifications at Settings - Lock screen and security - Other security settings - Notification access, make sure Always On Display it turned ON.
    I've gotten notifications from Android Messages (AKA Google Messenger) just fine.
    02-28-2017 02:26 PM
  3. Jason Tyler's Avatar
    I just noticed after the Nougat update my AOD notifcations are no longer appearing.
    It seems the notifcations only work if you have a lock screen setup.
    I didn't have a lock screen before and they worked. Now they don't.
    Anyway to get around this? I hate lock screens
    03-07-2017 12:29 PM
  4. ktabel01's Avatar
    I've noticed this too. Can't get any notifications via AOD unless I have a lock screen. Bummer
    03-07-2017 08:22 PM
  5. bsteppuhn's Avatar
    I have a lock screen and it won't even show me the icons of missed calls and msgs
    03-07-2017 09:50 PM
  6. Toes Up's Avatar
    Same here. Frustrating....
    03-07-2017 10:39 PM
  1. Can I upgrade android 4.4.4 on android car radio to 6.0?
    By jbright85 in forum General Help and How To
    Last Post: 03-02-2017, 11:18 AM
  2. Why can't I change the ringtone on my android phone ?
    Last Post: 02-28-2017, 01:58 PM
  3. Why does my Android keep beeping
    Last Post: 02-28-2017, 12:19 PM
  4. Free game and watchface
    By vader4633 in forum Samsung Gear S3
    Last Post: 02-28-2017, 11:53 AM
  5. Android messages icon indicates unread messages
    Last Post: 02-28-2017, 10:33 AM
