1. AC Question's Avatar
    am trying to connect to wifi router and unable to enter wps
    02-28-2017 04:31 PM
  2. smvim's Avatar
    You're better off just manually entering your WiFi SSID and password, WPS is NOT secure and should be avoided. WPS, deceptively stands for WiFI Protected Setup and is the exact opposite of 'Protected'. Router manufacturers started including WPS into their consumer products, making convenience the priority while ignoring security. ... and that's the focal point of almost all authentication procedures, the fact that one counters the other. Make something too secure and most people have problems and demand it to be more convenient. Conversely make it too convenient and there's little security. Finding a workable middle ground isn't easy.
    As for WPS, the sooner some class action lawsuit forces the manufacturers to either fix it or eliminate it completely can't come soon enough.
    https://www.howtogeek.com/176124/wi-...ld-disable-it/
    https://nakedsecurity.sophos.com/201...ur-own-crypto/
    https://www.dslreports.com/shownews/...-Use-It-137081
    https://en.wikipedia.org/wiki/Wi-Fi_Protected_Setup
    02-28-2017 07:03 PM
  1. How long will the headphone jack last?
    By jeffhuypham in forum LG V20
    Last Post: 02-28-2017, 10:53 PM
  2. Replies: 2
    Last Post: 02-28-2017, 07:36 PM
  3. Replies: 1
    Last Post: 02-28-2017, 05:39 PM
  4. Samsung Grand Prime SM-G530M problems with 4G/LTE signal
    Last Post: 02-28-2017, 04:09 PM
  5. my auto correct is off, how do I reset.
    Last Post: 02-28-2017, 04:07 PM
