1. AC Question's Avatar
    I have a galaxy s7 edge and the wifi will not connect. The wifi toggle switch is greyed out and stuck on "turning on..." forever. I have tried everything from clear cache and factory resetting my phone. How do I fix this?
    02-28-2017 07:57 PM
  2. IAmSixNine's Avatar
    Go into your settings, location, improve accuracy, make sure Bluetooth and Wifi are turned off.
    My note 4 and S7 Edge had a bug a while back where those (dont recall if it was WiFi or BT to improve accuracy) being turned on caused the wifi to toggle on and off and caused the phone to get hot and have bad battery life.
    You may need to power cycle once you turn those off.
    Dngrsone likes this.
    03-01-2017 08:43 AM
  3. galaxy1999's Avatar
    Does not work. Need more advice please.
    03-01-2017 03:11 PM
  4. IAmSixNine's Avatar
    Well, you have hard reset, wiped cache, if that fails its possible its a hardware failure. Sent to Samsung.
    03-02-2017 07:53 AM
  1. S7 locking again after entering pattern lock?
    By Cosmicyeee in forum Samsung Galaxy S7
    Last Post: 03-01-2017, 06:40 AM
  2. Galaxy s7 backup and deploy to new device
    Last Post: 02-28-2017, 07:30 PM
  3. can't connect to wifi can't turn on bluetooth.
    Last Post: 02-28-2017, 07:12 PM
  4. Replies: 0
    Last Post: 02-28-2017, 07:03 PM
  5. S7 Edge: can't switch keyboard in settings
    By virgipig in forum Samsung Galaxy S7 edge
    Last Post: 02-28-2017, 06:46 PM
