1. Raditya Kusuma Putra's Avatar
    please help, i just upgraded my android to nougat. but im having some problem.. i cant see the font especially in my messages list (pic attached).
    and not only the font in messages, i cant see the font on a top of setting menu (the text "setting" should appear on the white bar near search icon )
    is it just me having this "font contrast" problem or anybody else having same problem after upgrading to nougat?
    any advise would be appreciated.
    thanks
    Attached Thumbnails help: can't see the font on Nougat-screenshot_20170302-233745.jpg   help: can't see the font on Nougat-screenshot_20170302-233800.jpg
    03-02-2017 10:55 AM
  2. msndrstood's Avatar
    Go to screen and font and change the font size, if you use Nova, you can do the same there as well.
    03-02-2017 12:02 PM
  3. chanchan05's Avatar
    S7? Change to default theme.
    LineKill likes this.
    03-02-2017 08:33 PM
  4. LineKill's Avatar
    chanchan05 is right and this will correct your problem. If you do not like the default theme just choose a different one.
    03-02-2017 08:50 PM
  5. Raditya Kusuma Putra's Avatar
    thanks for the advise.. i should do that at first time. it works
    03-02-2017 11:24 PM
  1. Replies: 1
    Last Post: 03-31-2017, 12:45 AM
  2. Replies: 1
    Last Post: 03-02-2017, 05:19 PM
  3. Who is the genius that gave the ok to the new update ?
    Last Post: 03-02-2017, 01:11 PM
  4. Samsung S7 Nougat 7.0 Phone Call Log
    Last Post: 03-02-2017, 12:15 PM
  5. How do I remove the little numbers on the Messenger+ symbol ?
    Last Post: 03-02-2017, 10:02 AM
