05-19-2017 02:20 AM
202 ... 23456 ...
tools
  1. droidtgray's Avatar
    Duplicate
    03-08-2017 10:35 AM
  2. pounder001's Avatar
    AT&T user received the Google Assistant update sometime this morning. Haven't had time to mess with it yet though
    03-08-2017 11:46 AM
  3. pontiac005's Avatar
    Got mine last night. Don't know how as nothing was updated that I was aware of.
    03-08-2017 11:55 AM
  4. Oscarillo1's Avatar
    Got mine this morning.
    03-08-2017 02:00 PM
  5. djlee0314's Avatar
    Finally got Assistant as well this morning. Wasn't notified of any new update but just long pressed home button. T-Mobile user in Seattle, WA
    03-08-2017 02:02 PM
  6. Almeuit's Avatar
    Location doesn't matter, everyone :P.
    03-08-2017 03:04 PM
  7. droidtgray's Avatar
    OK, now how do I get it to go away?
    Now the home button long-press brings up a prompt for voice entry, and there's no setting I can find to bring up text entry or the Google Now feed. I can start the Google App from the launcher, which opens the familiar Google Now feed, and allows text entry.
    This update has rendered search almost useless to me. When I want to use voice, I say, "OK, Google." When i want to manually enter a search, I manually press the home button. Except now the shortcut for text search is gone. **** you, Google.
    Until they fix this you can go to language settings and change your default language to English us virgin islands. Google assistant does not support this language yet so the home button will now default back to google now with text entry options. There is also home2shortcut in the play store I have used in the past that lets you reprogram some buttons to launch the app you want.
    1naturalace likes this.
    03-08-2017 03:11 PM
  8. KindalRL's Avatar
    Still nothing for me, and I'm up to date on all software. I'm starting to feel like the kid who brought a bag lunch on pizza day.
    msndrstood likes this.
    03-08-2017 06:47 PM
  9. djlee0314's Avatar
    It just dawned on me that I did a manual restart (something I do weekly for maintenance) when I woke up this morning and also received the Assistant update. Not sure if it's just coincidence but if you're still waiting maybe give it a shot!
    03-08-2017 06:51 PM
  10. PraetorianGuard14's Avatar
    Has anyone gotten the update while using the Play Services beta program?
    03-08-2017 08:51 PM
  11. mmcclure0453's Avatar
    Just checked for GA and it's there. No update or anything. Just showed up out of the blue on my Verizon S7E.... Pretty cool.
    03-08-2017 09:43 PM
  12. pankaj981's Avatar
    Yep received it on play services beta on my Exynos s7 edge.
    03-08-2017 10:09 PM
  13. docbill's Avatar
    Exactly what happened to me. Verizon and S7 Edge
    03-08-2017 10:18 PM
  14. KindalRL's Avatar
    I was beginning to think the same thing...Is the beta keeping me from receiving it?
    03-08-2017 10:38 PM
  15. Kilroy672's Avatar
    What is the main difference between Google now and Google assistant? I've had Google assistant for a few days now and yet to use it.
    03-08-2017 11:04 PM
  16. Almeuit's Avatar
    It's basically Google Now but has AI so it can keep the context of a conversation.
    03-08-2017 11:38 PM
  17. valleyboy22's Avatar
    anyone in the UK received this yet??
    03-09-2017 12:55 AM
  18. Andyvalver's Avatar
    I'm in the UK and I haven't received it yet. I have an s7 edge and got the android nougat update a couple of days ago, but no assistant.
    03-09-2017 03:03 AM
  19. Zobbyb's Avatar
    I'm UK unlocked s7 edge. Nougat. No assistant for me yet.
    03-09-2017 04:38 AM
  20. Rumblee1's Avatar
    Well, I'm convinced. Not everyone is getting Google assistant. I've got 3 android devices and none have received it yet. I know that I should get it on all 3 at the same time because it will come down from my Google play store account, but what's the hold up?
    03-09-2017 06:01 AM
  21. Andyvalver's Avatar
    Question for the people who have had the update. Does it come as an app update in the store or does it just happen?
    03-09-2017 06:35 AM
  22. sweetypie31's Avatar
    It just happened for me. I went to use Google now and the assistant setup popped up.
    03-09-2017 07:54 AM
  23. LeoRex's Avatar
    Assistant is an evolution of Now/On Tap. First... the most obvious change is the interface when you launch the On Tap/Screen Search interface. Previously, it would give you a list of action icons.. stuff like finding a gas station or ATM, etc. Then it would search your screen and try to give you relevant information based on that. With Assistant, it alters the interface, moving to a voice based system rather than a touch based.
    The second main difference is a little bit more subtle and has to do with the voice interaction. With Now, it was relatively basic.... it would transcribe your query into a direct Google search and give you results. There were some commands, but they were a bit rigid and you had to know them to use them.
    With Assistant, Google enhanced things... rather that it transcribing your query into a Google search, it attempts to understand you in a more conversational tone. It is more able to interact with you when you use natural speech, and then also retains context. So when you ask "Are there any Thai restaurants near me?" After it gives you a list, you ask "When does it open?" and it will understand.
    Assistant attempts to improve on what a lot of people complain about.... rather than dictating commands, people want to speak in a natural way without having to memorize particular syntax and commands.
    03-09-2017 08:30 AM
  24. pixelflow's Avatar
    Yes
    03-09-2017 01:45 PM
  25. drusum's Avatar
    Haven't received this yet. Do I have to set up cards and stuff for this to work?
    03-09-2017 03:09 PM
202 ... 23456 ...
  1. Replies: 20
    Last Post: 08-03-2018, 09:21 AM
  2. Somehow my Moto G no longer has any keyboard.
    Last Post: 03-05-2017, 02:29 AM
  3. Why is Google Maps cutting off on the bottom portion?
    Last Post: 03-03-2017, 04:18 PM
  4. Phone not receiving email alerts until i refresh???
    Last Post: 03-02-2017, 12:39 PM
  5. How to root my Huawei 4C but Setting cant open or has stopped
    Last Post: 03-02-2017, 12:35 PM
