1. Lowgybear3's Avatar
    S7 edge here with Verizon.. Aka slowest carrier to push out updates ever. I was wondering if anyone has successfully sidloaded Nougat on their s7 edge. I'd like to try it. (no root)
    03-04-2017 11:13 PM
  2. wrich2005's Avatar
    You can load the beta
    03-04-2017 11:29 PM
  3. Est_XCIV's Avatar
    I have sideloaded it but I'm on ATT. It's smooth and works fine.
    03-05-2017 12:06 AM
  4. Lowgybear3's Avatar
    How did you do it?
    03-05-2017 08:44 AM
  5. Hey I Tried's Avatar
    You don't want to side load, front load, or any load an AT&T firmware on your Verizon phone.
    I know it sucks, I have Verizon too, and waiting can be a pain.
    People are having enough random issues after the N upgrade, you don't want compound those problems by loading another carriers firmware on your carrier locked (I'm just assuming on that one) Verizon phone.
    If you can find the beta for Verizon, you should be able to install that using Odin, but remember, it's called a beta for a reason.
    Betas are buggy, they are for real world testing and identifying bugs and issues.
    But, if you want to load the beta, go for it. It's your phone. But, don't load AT&T's firmware.
    03-05-2017 09:09 AM
  6. hallux's Avatar
    There appears to only be one SKU for the GS7 Edge in the US, despite carrier branding. Also, all Verizon-branded devices are unlocked.
    Device Unlocking Policy | About Verizon
    That said, it's probably not a good idea to load an AT&T Nougat build on a Verizon-branded device.
    03-06-2017 08:54 AM
  7. Lepa79's Avatar
    03-06-2017 08:56 AM
  8. Lowgybear3's Avatar
    Yesssssss!!! Thank you so much!
    03-06-2017 11:11 AM
  9. Lowgybear3's Avatar
    Any chance it comes with Google assistant?
    03-06-2017 12:47 PM
  10. Hey I Tried's Avatar
    Just upgraded, and it has Google Assistant.
    03-06-2017 04:46 PM
  11. Lowgybear3's Avatar
    Mine didn't come with assistant 👎
    03-06-2017 08:56 PM
  12. Hey I Tried's Avatar
    Press and hold the Home button. It should come up.
    I didn't have Assistant before the upgrade, so I know it wasn't carried over.
    03-06-2017 09:15 PM
  1. Android System eating battery after Nougat
    By crystinonfire in forum Samsung Galaxy S7 edge
    Last Post: 06-22-2018, 03:51 PM
  2. Change view of favorite contacts in Android Nougat
    Last Post: 03-18-2017, 07:45 AM
  3. Nougat-What happened to Wifi Calling?
    Last Post: 03-04-2017, 09:58 PM
  4. nougat on s7
    By swagglepuff in forum Samsung Galaxy S7
    Last Post: 03-04-2017, 02:30 AM
  5. AOD Nougat update
    By Abbers727 in forum Samsung Galaxy S7 edge
    Last Post: 03-03-2017, 09:56 PM
