1. AC Question's Avatar
    Hey guys! I'm at a bit of a standstill.
    I just purchased a Galaxy S7 Edge (T-Mobile if it matters) and I'm having some issues with a few games. For some reason, most of them just won't load over WiFi but they load perfectly over mobile data. Here's a few prime examples:
    NFL Mobile. When connected to WiFi, the game gets stuck at "Signing Contracts." Eventually it times out and says I need to be connected to the internet. The second I turn off wifi the game immediately proceeds past the stuck screen and works just fine.
    Asphalt Xtreme: The game loads, but when you're finished with a race it says "getting card info" or something similar which it's essentially referring to the rewards. Over Wifi, the connection times out. Over mobile data, it works instantly.
    I've only found a few 'fixes' over the internet and none have worked. I haven't tried the factory reset yet but I will if it's my only option. Here's a few things I found online which I've tried, yet no luck.
    Changing DHCP to Static in my phone.
    Updating DNS1 to
    Changing TKIPAES to AES
    I use a WRT500 connected via fiber optics, 300mbps if it matters. I'm set to IPv4 (doesn't even have an IPv6 option), PPPoE, WPAPSKWPA2PSK, changed TKIPAES to just AES, WPS is enabled, and I'm getting well over 200 MBPS from speedtests. Web browsing is normal, YouTube loads 1440p+ instantly, etc. My problem seems to be just the games. I've also tried this on my work WiFi, works just fine.
    So what do you think I should do here? Is the router the issue? Are there some sort of specific network changes I should make? Thank you for any insight.
    03-05-2017 05:31 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! The easiest way to tell if the problem is just with your router would be to try a different wi-fi network. Do you encounter the same problem if you connect to a wi-fi network at your local library or coffeeshop?
    03-05-2017 09:48 PM
  1. Upgrade from S5 to S7
    By tkavan in forum Samsung Galaxy S7
    Last Post: 03-10-2017, 06:07 PM
  2. what do i lose when i delete cache and data from messages
    Last Post: 03-05-2017, 09:02 PM
  3. How do i send and receive pics on Android huawei?
    Last Post: 03-05-2017, 06:02 PM
  4. Replies: 1
    Last Post: 03-05-2017, 05:23 PM
  5. Moving /data/data/com... to SD card?
    Last Post: 03-05-2017, 05:11 PM
