03-08-2017 11:38 PM
122 1234 ...
tools
  1. walkman666's Avatar
    Installing now...
    03-06-2017 03:12 PM
  2. pkcable's Avatar
    Verizon sure kept you guys waiting long enough! lol Glad you are finally getting it.
    03-06-2017 03:15 PM
  3. PJRed2008's Avatar
    The best are always last!
    03-06-2017 03:28 PM
  4. Lepa79's Avatar
    Got it about an hour ago. Installed but no factory reset. Probably going to do that tonight.
    03-06-2017 03:34 PM
  5. jmk32's Avatar
    Upgrade went without a hitch. Nice to see some of the features from the Note 7 now on here with performance mode, expanded notification shade, Always on Display with notifications now, etc. Phone is still settling down, so I expect some of the initial choppiness to go away in a day or so. Don't plan on doing a factory reset unless I encounter issues.
    Mark8768 and KPMcClave like this.
    03-06-2017 03:45 PM
  6. ZOMMBIE1's Avatar
    Reminds me of my Note 7 (RIP)...
    03-06-2017 03:48 PM
  7. LineKill's Avatar
    I am doing that right now myself. It's running nice, but there is nothing like freshly reset device.
    03-06-2017 04:19 PM
  8. LineKill's Avatar
    I really enjoy the updated AOD!
    03-06-2017 04:20 PM
  9. alimaeeeee's Avatar
    I have the S7, did the update, and now my LED isn't blinking when I get notifications. Anyone know how to fix it? Thanks!
    eewwyeah likes this.
    03-06-2017 04:20 PM
  10. lady of the lake's Avatar
    Mines downloaded but I'm hesitant to install it. I've got some traveling to do at the end of the week and I'm leading the group with all the flight, hotel, car arrangements made and stored on apps on my Verizon S7edge. Reading all the horror stories has me spooked.
    Once I install I can't go back to the old OS, is that correct? This is my first Android. I was a long time BlackBerry user and I'm not as familiar with this system.
    03-06-2017 04:21 PM
  11. Harlemknight's Avatar
    I got it, so far so good.
    03-06-2017 04:27 PM
  12. Frank Aiello's Avatar
    OK I got the notification and I said update now, the phone turned off as it would usually do in a update but the the boot screen came up and it's been stuck there now for 15 mins. What should I do, reboot?
    03-06-2017 04:36 PM
  13. LineKill's Avatar
    In settings go to display and make sure you have Led indicator turned on.
    03-06-2017 04:37 PM
  14. LineKill's Avatar
    You should wait until you get back before you update. There is nothing the update will give you that you need on your trip. It is better if you have a phone that you know is working and are familiar with. It is a big update, you can spend some time with it when you get back. You can go back to marshmallow but it not as easy as just hitting a downgrade button.
    03-06-2017 04:43 PM
  15. alimaeeeee's Avatar
    Yep, it's on. That's why I'm having trouble figuring out what's going on. I've been through a ton of the settings and can't figure out why it stopped working after the update.
    03-06-2017 04:46 PM
  16. LineKill's Avatar
    Try holding the power button until the phone turns off and then power it up again.
    03-06-2017 04:46 PM
  17. Frank Aiello's Avatar
    Restarted phone and went back to check for update and it's saying "update in process" but the phone is still usable?? Did I screw something up? Should I reboot or just wait it out?
    03-06-2017 04:52 PM
  18. drusum's Avatar
    Update went smoothly. Did a factory reset just in case there'd be any hiccups. Battery seems about the same for me. Loving the update so far.
    03-06-2017 05:12 PM
  19. bsteppuhn's Avatar
    Mine has gone smoothly so far
    03-06-2017 05:36 PM
  20. LineKill's Avatar
    I am not sure exactly where you are at. The update process does take a while. If you cannot cancel the update and restart the update wait for 45 minutes. If it appears that nothing is happening after this period try booting into recovery and wipe the partition cache.
    tabs31 likes this.
    03-06-2017 05:43 PM
  21. LineKill's Avatar
    I am glad most everyone is having a successful update. I have been using Nougat on the Verizon S7 edge for almost 4 months now. If anyone has any questions or problems I will do my best to answer and help.
    03-06-2017 05:48 PM
  22. jmunchies1's Avatar
    I had the same problem but a reboot seems to have fixed it.
    Edit: Spoke too soon, LED not working for me either. Worked once after reboot then stopped again.
    Anyone else with LED issues?
    03-06-2017 06:38 PM
  23. PJRed2008's Avatar
    Seeing as how you asked I really am not seeing much other than the new battery stats that I consider an improvement. And going way the other way is the totally sucko theme and wallpaper app that forces you to give permissions for phone, contacts and one other that I can't remember. Just to change wallpaper, that is way stupid. Have you perchance found something else to do that?
    03-06-2017 06:40 PM
  24. Mark8768's Avatar
    Updated mine... no big issues. My favorite theme is unusable but other then that not bad. A lot of note 7 in here which I love .... have to fiddle with my display settings some yet. Glad we finally got the update !
    03-06-2017 06:49 PM
  25. PraetorianGuard14's Avatar
    Just to make sure, was this update supposed to have the launcher shortcut feature? I don't have it on mine.
    03-06-2017 06:53 PM
122 1234 ...
  1. Gear S3 on Verizon
    By sealuva in forum Samsung Gear S3
    Last Post: 09-05-2017, 07:28 PM
  2. Replies: 6
    Last Post: 03-26-2017, 09:04 PM
  3. Replies: 11
    Last Post: 03-23-2017, 12:09 AM
  4. Will Verizon Galaxy S7 work on ATT?
    By AC Question in forum Samsung Galaxy S7
    Last Post: 03-08-2017, 07:32 PM
  5. Will Verizon Galaxy S7 work on ATT?
    Last Post: 03-05-2017, 10:15 PM
