Do I need to do a factory reset after this update?
I'm not sure what's going on with mine. At noon today the update was available. I tried to download but it wouldn't take. I assume it has something to do with my workplace wifi. I got home and tried again and it says no update is available for download. What gives?
Got it about an hour ago. Installed but no factory reset. Probably going to do that tonight.
Upgrade went without a hitch. Nice to see some of the features from the Note 7 now on here with performance mode, expanded notification shade, Always on Display with notifications now, etc. Phone is still settling down, so I expect some of the initial choppiness to go away in a day or so. Don't plan on doing a factory reset unless I encounter issues.
I have the S7, did the update, and now my LED isn't blinking when I get notifications. Anyone know how to fix it? Thanks!
Mines downloaded but I'm hesitant to install it. I've got some traveling to do at the end of the week and I'm leading the group with all the flight, hotel, car arrangements made and stored on apps on my Verizon S7edge. Reading all the horror stories has me spooked.
Once I install I can't go back to the old OS, is that correct? This is my first Android. I was a long time BlackBerry user and I'm not as familiar with this system.
In settings go to display and make sure you have Led indicator turned on.
