01-14-2018 01:47 PM
39 12
tools
  1. trucksmoveamerica#AC's Avatar
    I updated to the nougat on my Samsung S7 edge. Samsung had the feature of one handed use for things like the dial pad and calculator where you could have the number pad on right side of screen or left.
    I can't find that feature anymore, did Samsung take that away from us, or am I not finding the option. This feature was the main selling point for me on Samsung phones, if they took it away I may be looking at other phones harder. I can't believe they took that away.
    03-06-2017 04:00 PM
  2. antman451's Avatar
    I saw it in the settings menu somewhere after I upgraded to Nougat. I don't remember where, since I don't use it much.
    03-06-2017 04:01 PM
  3. trucksmoveamerica#AC's Avatar
    There's a one handed option in the settings but that's just to reduce the screen size, don't see anything to change the dial pad or calculated keypad to one or the other side. I hope it's somewhere, but I can't find it.
    03-06-2017 04:09 PM
  4. bandofbrothers2112's Avatar
    I used the reduced keyboard size and the option to have the keyboard either on the Rh or Lh too.
    At present I'm unable to find anything in settings.
    03-06-2017 04:12 PM
  5. msndrstood's Avatar
    I have it, it's under advanced settings.
    pankaj981 likes this.
    03-06-2017 05:03 PM
  6. trucksmoveamerica#AC's Avatar
    I have it, it's under advanced settings. https://uploads.tapatalk-cdn.com/201...be60a403c9.jpg
    I have that to, all it offers now is reduce the screen. Before the update you had a setting to position the keyboard, dialpad, and calculator keypad to the right side or left side whichever you chose. Thinking they dropped it, shame it was one of the main reasons I went with Samsung.
    03-06-2017 06:54 PM
  7. msndrstood's Avatar
    Like this?
    03-06-2017 06:57 PM
  8. msndrstood's Avatar
    Like this
    03-06-2017 06:58 PM
  9. trucksmoveamerica#AC's Avatar
    I have that. Like the dialpad below. I googled that.
    03-06-2017 07:04 PM
  10. msndrstood's Avatar
    This is what I have for the dual pad, I'm not sure if this isn't it.
    03-06-2017 07:06 PM
  11. trucksmoveamerica#AC's Avatar
    Yeah that requires extra steps to get to that. The example I showed you was set up to be that way in normal screen mode just by selecting phone app. The new method requires another step, so went backwards.
    Sucks, that's how Samsung has had me as a customer since note 3 days, without this feature opens up looking at other manufacturers. Think lg does it, can't remember
    03-06-2017 09:50 PM
  12. chanchan05's Avatar
    Personally, I don't see how it would be different in usage, especially since I prefer the current implementation better.
    LineKill likes this.
    03-07-2017 02:04 AM
  13. NexusGirlX's Avatar
    I believe this is what the OP was talking about. I can drag from the top right of the phones dial pad screen to bring it down to the lower left or drag from the top left and drag it down to the lower right.
    You can do this with other apps as well.
    Samsung S7 edge nougat update lost feature-screenshot_20170307-013653.jpgSamsung S7 edge nougat update lost feature-screenshot_20170307-013956.jpg
    sweetypie31 likes this.
    03-07-2017 03:40 AM
  14. LineKill's Avatar
    From what I saw in the screenshot you posted of the dial pad that you googled, I have not seen any settings that allow you to set it up that way. You have two options, the one-handed mode and what NexusGirlX just showed you.
    03-07-2017 06:14 AM
  15. trucksmoveamerica#AC's Avatar
    Yes that appears to be the new way in nougat. Before nougat you could set it up for the dial pad, calculator keypad, and the keyboard to do what I posted automatically when you opened them. You didn't have to reduce the screen size first, then open the dial pad or whatever.
    03-07-2017 08:02 AM
  16. NexusGirlX's Avatar
    The nice thing about resizing the phone app or the calculator app, is that you can hit the up/down arrow icon on the top left and it will just become an icon on your screen for as long as you leave it there. To open it when you need it, just tap on the icon and it will go to that small sized app again. Done with the app and reduce it to an icon again.
    03-07-2017 08:06 AM
  17. trucksmoveamerica#AC's Avatar
    This is what we lost. I took a screenshot from my daughters S7 edge that hasn't updated yet.
    Is there a way to contact Samsung about losing this feature and ask for it back?
    03-07-2017 08:12 AM
  18. chanchan05's Avatar
    You're talking about popup windows. That's still in Nougat. That's not what the OP was talking about.
    03-07-2017 08:14 AM
  19. trucksmoveamerica#AC's Avatar
    Thank you. I couldn't remember what exactly they called the feature I was talking about, then remembered my daughter has the S7 edge and hasn't updated yet.. I updated first post with my picture.
    03-07-2017 08:17 AM
  20. NexusGirlX's Avatar
    Well, what I posted above pretty much does the same thing. In the two screenshots below, you see the phone app reduced in size like you see in your example. The second screenshot shows what it looks like when you minimize it. It sits on your home screen at the top or wherever you decide to move it, looking like an app icon. Tap it and it opens again just as it does in the first screenshot. It can stay there as an icon as long as you want, forever even. This is probably why they got rid of doing this in the manner you are looking for.
    Samsung S7 edge nougat update lost feature-screenshot_20170307-061411.jpgSamsung S7 edge nougat update lost feature-screenshot_20170307-061421.jpg
    03-07-2017 08:18 AM
  21. NexusGirlX's Avatar
    It is pretty much the same exact thing which is why they probably removed what the OP wants and left this in.
    03-07-2017 08:20 AM
  22. trucksmoveamerica#AC's Avatar
ID:	253638Click image for larger version.
    I know it does, but one it requires an extra step to reduce screen size and it also makes everything smaller, such as the words. The old way everything stays original size, just reduces keypads and puts it on the side you want it.
    When you get older reducing size isn't always the best solution with eyesight getting a little worse with age.
    03-07-2017 08:24 AM
  23. NexusGirlX's Avatar
    I understand. I still have a Note 5 and my US unlocked S7 Edge on MM. I don't really plan on upgrading them to Nougat. Luckily, I have another S7 Edge on Nougat so I can have the best of both versions.
    The thing that I don't like about reduces the size in the keyboard in all apps. It would be nice if you could just reduce the size of say just the keypad in the phone app.
    03-07-2017 08:28 AM
  24. trucksmoveamerica#AC's Avatar
    That would be nice to select which ones. I'll put a picture up, but it appears Samsung also took away your feature of making short cut and what size you want and the ability to put anywhere on the screen. There's no options on the top to do that anymore. Is it somewhere else now?
    03-07-2017 08:34 AM
  25. NexusGirlX's Avatar
    The screencaps I posted above were done on a S7 Edge running Nougat.
    03-07-2017 08:36 AM
39 12
  1. Digital version of the Samsung Gear 3
    By NoNoiPhone4me in forum Samsung Gear S3
    Last Post: 03-08-2017, 02:51 PM
  2. Replies: 4
    Last Post: 03-07-2017, 07:30 PM
  3. S7 edge nougat turning off the phone
    By ELvinasjuo in forum Samsung Galaxy S7 edge
    Last Post: 03-06-2017, 04:26 PM
  4. Replies: 1
    Last Post: 03-06-2017, 03:54 PM
  5. Replies: 0
    Last Post: 03-06-2017, 02:41 PM
