1. JordySimo's Avatar
    Hi all.
    So today, I was finally able to download and install Nougat onto my S7 Edge but as I was trying to figure things out, I noticed there was no automatic power saving feature that you can set to start at 20% or even 15%, like there was on Marshmallow. Bit disappointing.
    What's confusing me most is the "App power monitor" section. With Marshmallow, I was able to set all the apps to always save power so that no apps were killing my battery in the background, so I was curious on what the equivalent to app power saving is on Nougat...
    When I tick each application under the app power monitor and then click the blue "save power" button at the top, all the apps are removed from the section and it tells me that "...... battery draining apps have been removed", or something along those lines. But they keep reappearing even though I've killed them off. Is there any way I can set it so that the apps automatically stop running and are killed off when I close the application?
    So yeah, just a little help on understanding killing apps automatically in the background on Nougat would be great, thanks.
    Attached Thumbnails Nougat: Power Saving & App Power Saving-screenshot_20170306-220819.png
    03-06-2017 05:12 PM
  2. anon(238680)'s Avatar
    As soon as you activate a sleeping app it loses the power off feature, you have to reset it again. Not really useful for most apps unless you have one that is constantly accessing data. I also haven't found the low battery level alarm but have only had noug for a couple hours.
    03-06-2017 08:14 PM
  3. AuthorTim13's Avatar
    Hi all.
    07-19-2017 04:18 PM
  4. AuthorTim13's Avatar
    I have the same question. As well as why do apps that I haven't opened in forever keep showing up as draining power?
    Hi all.
    07-19-2017 04:20 PM
  5. Tsepz_GP's Avatar
    The App Monitor is now in a deep setting.
    Go to Battery hit the 3dots at the top right - Advanced Settings -App Power Monitor, you get this:
    07-20-2017 02:25 PM
  6. Abbers727's Avatar
    The lowest % of when you get notified is: 30%. It tells you that you'll always get notified when your phone gets down to 15%. I don't know if there's a way to automatically put it into power saving mode once it reaches a certain %.
    07-20-2017 05:47 PM
  7. Ipse_Tase's Avatar
    This kind of stuff kept me off Nougat and on Marshmallow + Greenify....at least I can control every app individually.
    07-23-2017 11:05 AM
  1. Samsung S7 edge nougat update lost feature
    By trucksmoveamerica#AC in forum Samsung Galaxy S7 edge
    Last Post: 01-14-2018, 01:47 PM
  2. Any hope for Nougat?
    By frellingfrakker in forum Samsung Galaxy Note 4
    Last Post: 03-14-2017, 11:45 AM
  3. com.sec.android.app.videoplayer
    Last Post: 03-07-2017, 03:17 PM
  4. S7 edge nougat turning off the phone
    By ELvinasjuo in forum Samsung Galaxy S7 edge
    Last Post: 03-06-2017, 04:26 PM
  5. Cannot transfer apps to SD
    Last Post: 03-06-2017, 01:23 PM
