1. AC Question's Avatar
    Just got the nougat update last night and today for my s7 edge on verizon and Facebook badge notifications won't go away...even when I gave no new notification it still says I do.
    Also when I close an app it doesn't go back to the home screen it takes me back to the app folder instead.. how do I make it auto close that folder after i select the app in it.... any suggestions on fixes?
    03-08-2017 07:22 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Open your App Manager, tap Menu>Show System, and look for something along the lines of "BadgeProvider." Select it, tap Storage, then Clear Cache/Clear Data. Now see if the badge count problem persists.
    How are you exiting your apps -- by tapping Back or Home? If you tap Back, and if you opened your app from App Drawer, it will dump you back to the App Drawer. Pressing the Home button will bring you to the homescreen.
    03-09-2017 05:24 PM
  1. Having an issue with talk to text on my Galaxy Note 5
    By tony2163 in forum Samsung Galaxy Note 5
    Last Post: 03-08-2017, 11:12 PM
  2. Replies: 1
    Last Post: 03-08-2017, 07:38 PM
  3. Where did my clock and weather go?
    Last Post: 03-08-2017, 07:29 PM
  4. why won't anyone answer the text issue question?
    Last Post: 03-08-2017, 06:24 PM
  5. Replies: 1
    Last Post: 03-08-2017, 06:22 PM
