DrifterYank
Re: Verizon Nougat Help, Tips & Tricks
Okay now I have it. I had to go into widgets and display the Galaxy Essentials widget on the screen. Then when I tapped on that it brought up the screen that you show. I have now added the Secure Folder button and I'm about to put some things in there.
Thanks a lot for your help on this. It is very strange that this would not show up and that I had to activate a widget in order to get going.
I have not added it to my quick settings yet, but when you edit the panel it should be at the bottom.
