1. AC Question's Avatar
    After recent update, s7 edge will not decrypt my sd card. It keeps saying i have to decrypt in the phone used to encrypt..but it IS THE SAME PHONE! How can i fix this?
    03-09-2017 02:26 AM
  2. Gary02468's Avatar
    Does it ask you for your password, or does it just give you the error message without asking for the password first?
    Also, has your phone ever been rooted?
    03-09-2017 06:23 AM
  3. lime7's Avatar
    This happened to me too!
    Had my SD-card encrypted for almost a year, and everything working perfectly. then i updated to Android 7.0 and it was unreadable. i tried to decrypt and i just decrypted a very small portion of the card. like 200MB. even though there are like 40GB worth of files on the card. i have tried restarting, decrypting and encrypting again. After i removed the SD card and just put it back in the phone it gave me the message that this was not the same phone that the card got encrypted with in the first place! even though it most certainly is.
    model: SM-G935F
    SD card: 128GB Samsung EVO (GENUINE card)
    03-13-2017 06:35 AM
  4. lime7's Avatar
    my phone was never rooted btw. and it did ask for the password at first but only decrypted a small portion of the data. after i reinserted the card it would not even recognize that this was the same phone that encrypted it.
    03-13-2017 11:08 AM
  5. ezapper2's Avatar
    model: SM-G935F
    I have the same issue. Worst thing you can do is decrypt. The only thing you can do now is run an app for recovery.
    I had this issue when upgrading originally from lollipop to marshmallow. The trick was to disable security. However it did not work for me this time going to nougat.
    It just doesn't read the card anymore
    03-23-2017 12:04 AM
  6. jeetu4444's Avatar
    In my wife's s7 edge after nougat update the SD card is not reading anymore... Weird.. Any fix?
    03-26-2017 09:20 AM
  1. S7 Edge Nougat Performance Mode
    By imlegend84 in forum Samsung Galaxy S7 edge
    Last Post: 04-11-2017, 08:48 AM
  2. Verizon S7 edge - Nougat Help, Tips & Tricks
    By magerb in forum Samsung Galaxy S7 edge
    Last Post: 03-28-2017, 07:59 PM
  3. Replies: 4
    Last Post: 03-09-2017, 03:09 PM
  4. Can sim card owner steal my network credentials?
    Last Post: 03-09-2017, 12:06 PM
  5. my samsung galaxy s7 edge Snote not working after nougat update
    By AC Question in forum Samsung Galaxy S7 edge
    Last Post: 03-09-2017, 01:21 AM
