1. AC Question's Avatar
    I have used split screen mode for the past 3 months, and last week, the bubble on top of the most recent app used to change how much screen the app takes up has disappeared. Whenever I use split screen mode, I am stuck with both apps sharing half of my screen, with no way to adjust it. Is there any way to get the drag bubble back? Thanks in advance
    03-09-2017 08:30 AM
  2. lammy8's Avatar
    No, with nougat it's androids own split screen view which doesn't have custom sizing
    03-09-2017 07:50 PM
  3. LineKill's Avatar
    You cannot change the size in landscape but you can in portrait.
    03-09-2017 07:59 PM
  4. ZOMMBIE1's Avatar
    If you swipe from the top left corner you can adjust both in landscape mode. Just not as easy as before Google's version messed it up.
    03-09-2017 08:31 PM
  5. Bosbouer's Avatar
    Simply dragging the deviding line between the open windows changes the size in both landscape and portrait view in Nougat....
    03-09-2017 10:58 PM
  1. Default Samsung S7 Edge Wallpaper
    By Liger86 in forum Samsung Galaxy S7 edge
    Last Post: 03-19-2017, 03:16 PM
  2. Replies: 8
    Last Post: 03-14-2017, 11:16 AM
  3. Can I import texts from old device to new?
    Last Post: 03-09-2017, 06:10 PM
  4. Why does my camera light randomly turn on?
    By Fire Blaze in forum Ask a Question
    Last Post: 03-09-2017, 05:39 PM
  5. After upgrade to Android 7.0 pictures of my phone contacts lost
    By AC Question in forum Samsung Galaxy S7
    Last Post: 03-09-2017, 03:49 PM
