1. Steve Swift's Avatar
    Nearly all of my contacts phone numbers are UK numbers, which start with a "0". A few of them have international prefixes, such as +45
    Is there an easy way to update the phone numbers in my contacts, so that numbers which start with a "0" have the leading "0" replaced by "+44"
    03-10-2017 11:10 AM
  2. SpookDroid's Avatar
    The only way I can think of is to export your Contact list to a file (VCF), open that list in Excel, use the 'Search/Replace' function to do what you need, and replace your current contact list with the edited file.
    There's no easy way of doing that natively or on Google's site (I had to manually edit each of my contacts when I moved to another country).
    Laura Knotek likes this.
    03-10-2017 11:52 AM
  3. Steve Swift's Avatar
    Thank you for the information. When I export the contacts file as vcf, then use it to replace the original contacts file, presumably I'd find it easier to use the excel app in one of my Android devices, rather than using my Windows 10 PC?
    I'm wary of transferring files between systems, as I might run into code page variations.
    I'll give it a shot and see how far I get.
    I'll see if I can take a copy of the contacts data before I start, as I live in fear of screwing up my phone or tablet. My android skills are puny compared to my Windows skills, but I've wrecked Windows systems in my time...
    03-10-2017 02:29 PM
  4. SpookDroid's Avatar
    As long as you keep a copy of the VCF file you should be good, and in the event of 'disaster', if your contacts are backed up to your Google account, you can always go back to any previous day within the last 30 days.
    03-10-2017 02:42 PM
  1. New Clear All Recent Apps button
    By rbess1965 in forum Motorola Droid Turbo
    Last Post: 05-06-2017, 03:25 AM
  2. Mysterious photo transfer from S7 to S6
    Last Post: 03-10-2017, 11:21 AM
  3. Replies: 1
    Last Post: 03-10-2017, 11:17 AM
  4. Replies: 1
    Last Post: 03-10-2017, 11:16 AM
  5. When did my Moto Phone get a Clear All Recent Apps button.
    By rbess1965 in forum Ask a Question
    Last Post: 03-10-2017, 11:14 AM
