1. AC Question's Avatar
    After I download a app I try to move the icon from the home screen by hold and drag to delete but it don't let me do that
    03-10-2017 01:53 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Are you in Easy Mode? How to use Easy Mode on the Samsung Galaxy S7 | Android Central
    03-11-2017 11:37 PM
  3. pontiac005's Avatar
    You can also hold your finger on the app, choose icon options and then remove.
    03-12-2017 12:09 AM
  1. Formatting the internal memory?
    By mwake4goten in forum Samsung Galaxy Note 5
    Last Post: 06-27-2017, 10:11 AM
  2. Replies: 1
    Last Post: 03-11-2017, 11:40 PM
  3. Ok, figured out my battery problem now I have a BT problem
    Last Post: 03-11-2017, 11:38 PM
  4. proxy and java script apps
    Last Post: 03-10-2017, 04:31 PM
  5. How to release someone off a message block list.
    Last Post: 03-10-2017, 03:00 PM
