Is Textra the best texting app?
StephaneM60
52
it's a nice texting app. You can customize it in almost every possible way. Good support for emoticons, gif and other apps (drivemode, android wear, gboard...). You can assign a specific tone for each contact.
Though, i reverted to stock messaging app because textra failed to send mms for me (my provider set a 600kb limit on mms and textra doesn't compress videos when yo add them : both stock messaging and android messages can so...). Even though I contacted support about this, they replied back to tell me that level 2 support should recontact me and as of today they never did.
Note : my S7 is still on Marshmallow...
Est_XCIV
122
I have an issue on Textra with not being able to see messages that i have sent. I can see messages that I have received. This also applies to other 3rd party messaging apps. Any suggestions?
cbreze
2,876
86
48
My only gripe is when I hit send it closes the app and I have to reopen it every time to re-read what I wrote or others. This, even tho I have the option to do that unselected.
LineKill
1,801
I don't use Textra myself, but if you have not already tried, select the option and then unselect it again. See if that knocks some sense into it.
cbreze
2,876
86
48
Yeah, thanks, tried that a few times. Might actually go back to Message + as I liked that a lot and came over to Textra only the past 2 or weeks ago to try it out.
LineKill
1,801
That's what I used to use it is pretty decent, now I have it disabled and just use Messages. I am not much of a texter. I just send basic text now and then. I do see the attraction for Textra for those that are into it though.
MarkMN
57
I don't know if it's the best, but Textra is my favorite text app. It does everything I need it for and I can customize it the way I like.
Mark
Golfdriver97
Trusted Member Team Leader
Moderator
Dec 4, 2012
35,367
113
63
I like Textra. I am currently using it as me default SMS app. I don't have any issues for the way I have it set up.
Almeuit
Moderator Team Leader
Moderator
Apr 17, 2012
32,277
23
I personally love Textra. The quick reply along with the customization has me using them as my default app :).
asha_kanta_sharma
