1. AC Question's Avatar
    I have a gaxaxy s7 edge and at night I turn all volumes down so not disturbed while sleeping only to be woke up to notification or phone calls ect. It's driving me batty
    03-12-2017 10:47 AM
  2. Golfdriver97's Avatar
    Welcome to the forums. Are you using the built in Do Not Disturb in Settings>sound?
    03-12-2017 11:22 AM
  3. Hey I Tried's Avatar
    100% correct with this suggestion. The Do Not Disturb function should help alleviate a lot of night time interruptions.
    Setup is very easy and straightforward, and it can be set to enable/disable on a schedule, and can be manually enabled / disabled through the quick settings.
    03-12-2017 12:25 PM
  4. Letsjoke57's Avatar
    Yes I have do not disturb set on phone,and when I was still occasionally getting disturbed I started additionally turning all volumes down .ringer volume gets stightly turned up with notification volume and systwm volume turned back to max volume.
    03-12-2017 01:22 PM
  5. Hey I Tried's Avatar
    Check the additional settings for the Do Not Disturb.
    Gives you more control over what shows, what alerts.
    03-12-2017 02:49 PM
  1. my phone keeps freezing no matter what
    By AC Question in forum Samsung Galaxy S7 edge
    Last Post: 03-13-2017, 02:00 AM
  2. why am I needing to change ( swap) the language of the keyboard ?
    Last Post: 03-12-2017, 11:20 AM
  3. Replies: 0
    Last Post: 03-12-2017, 10:24 AM
  4. Replies: 0
    Last Post: 03-12-2017, 10:21 AM
  5. Replies: 0
