Originally Posted by
Flipout789 Okay but thing is when i dont use it i have all the verizon stuff running in the background wont that hurt it a little?
Thing is i came from having a iphone 6 and i feel like im getting worse battery life than a iphone from 2014. Shouldn't I?
You can disable or delete all of the Verizon bloatware accept for Voicemail with the built-in application manager in settings.
In settings go to Applications and then select the app you do not want. From there you can uninstall the app, if uninstall is not available you can disable it.
