1. AC Question's Avatar
    Hi Everyone,
    On my Samsung S7 Edge, there is only 1 choice for the English language. How do I download and add English (United Kingdom) to this list so I can have the Google Assistant respond in that language?
    Thanks.
    03-18-2017 09:23 AM
  2. LineKill's Avatar
    Go to add languages and then click on the 3 dots and tap on all languages. If you go into English from there you will see United Kingdom listed.
    03-18-2017 10:49 AM
  3. emadeva's Avatar
    Hi magerb,
    "Add Language" is not listed on my screen when I tap the following:
    Settings -> Language and input
    If I tap "Language", there is only 1 choice for English. I need to add English (United Kingdom)
    All that is shows after tapping "Language and input" is:
    Language
    Default Keyboard
    Gboard
    Google voice typing
    Samsung keyboard
    Text-to-speech
    Pointer speed
    The 3 dots icon is not showing up. All documentation I've seen on the internet states there should be "Add language" but it's not there.
    I'm using using Marshmallow 6.0.1 for the OS.
    Thanks.
    03-18-2017 02:04 PM
  4. LineKill's Avatar
    I cannot remember on Marshmellow anymore, it's been 5 months and I am old:-) Let me see if a few images help. Tap on each item I have circled. It may look a little different. I started at language and input. If this does not help, I am sorry.How do you add a default language to S7 Edge-screenshot_20170318-120906.jpgHow do you add a default language to S7 Edge-screenshot_20170318-120932.jpgHow do you add a default language to S7 Edge-screenshot_20170318-121011.jpgHow do you add a default language to S7 Edge-screenshot_20170318-121037.jpgHow do you add a default language to S7 Edge-screenshot_20170318-121116.jpgHow do you add a default language to S7 Edge-screenshot_20170318-121145.jpg
    03-18-2017 02:17 PM
  5. emadeva's Avatar
    I cannot remember on Marshmellow anymore, it's been 5 months and I am old:-) Let me see if a few images help. Tap on each item I have circled. It may look a little different. I started at language and input. If this does not help, I am sorry.Click image for larger version.
ID:	254435Click image for larger version.
ID:	254436Click image for larger version.
ID:	254437Click image for larger version.
ID:	254438Click image for larger version.
ID:	254439Click image for larger version.
    Hi,
    My screen is very much different under "Language and input". Looks like the Galaxy S7 Edge is different than your phone because my other phone which is the Samsung Galaxy J7 does allow me to change or add the Language and has the same screens as your screen shots.
    Truly,
    Emad
    03-18-2017 02:35 PM
  6. LineKill's Avatar
    Hi,
    Truly,
    Emad
    I am sorry I could not help. I am using the S7 edge with Nougat 7.0.
    03-18-2017 02:40 PM
  7. emadeva's Avatar
    Hi,
    How did you get Nougat? I tried "Download updates manually" but it tells me I"m on the latest version even though I know Nougat is the latest version.
    Thanks for trying anyway.
    03-18-2017 02:48 PM
  8. LineKill's Avatar
    Hi,
    I am with Verizon in the US. Your welcome😊
    Maybe someone else will be able to help.
    03-18-2017 02:50 PM
  9. emadeva's Avatar
    Hi,
    Looks like that ability is only available to locked phones by a carrier. Mine is an unlocked phone from Bestbuy.
    I found the Samsung support forum and posted over there as well to see if they can push an update so I will be current.
    03-18-2017 02:53 PM
  10. LineKill's Avatar
    Hi,
    Yeah, Samsung has really fallen behind with the US unlocked model.
    03-18-2017 02:55 PM
  11. emadeva's Avatar
    Yeah, Samsung has really fallen behind with the US Unlocked model.
    I hope it's soon.
    LineKill likes this.
    03-18-2017 02:57 PM
  1. Universal Switch keeps trying to turn on. (Samsung S6)
    By Guest218923 in forum Ask a Question
    Last Post: 03-21-2018, 01:22 PM
  2. S7 edge back button lag
    By bazzauk in forum Samsung Galaxy S7 edge
    Last Post: 04-02-2017, 08:47 PM
  3. How to find no.of contacts in android phone?
    By AC Question in forum Moto G (2014)
    Last Post: 03-18-2017, 09:52 AM
  4. Replies: 0
    Last Post: 03-18-2017, 07:17 AM
  5. How to find no.of contacts in android phone?
    Last Post: 03-18-2017, 06:59 AM
