1. bandofbrothers2112's Avatar
    I'm on Nougat using the default theme right now.
    Now I'm happy with those icons.
    Anyone know of a Dark Theme that does not change the icons.
    03-18-2017 10:36 AM
  2. trucksmoveamerica#AC's Avatar
    I use NOVA prime so my icons don't change in themes. I love that they don't change.
    bandofbrothers2112 likes this.
    03-18-2017 10:49 AM
  3. LineKill's Avatar
    After you change the theme you can go into icons and chose the default icons.
    03-18-2017 10:55 AM
  4. bandofbrothers2112's Avatar
    How please ?
    It's ok I worked it out.
    Thank you for the heads up that this can be achieved however.
    LineKill likes this.
    03-18-2017 11:00 AM
  5. LineKill's Avatar
    How please ?
    At the top in the theme store there are 3 tabs. After you change your theme go into the icons tab and select default.
    03-18-2017 11:04 AM
  1. Questions about nougat update
    By ahiqar in forum Samsung Galaxy S7
    Last Post: 03-22-2017, 05:15 PM
  2. Buying a 3 or 3T, a quick question
    By NightOrchid in forum OnePlus 3 & 3T
    Last Post: 03-20-2017, 02:11 PM
  3. Purchase Question (Verizon)
    By -Myk- in forum LG G6
    Last Post: 03-19-2017, 08:58 AM
  4. SD Card Question
    By frifred in forum LG G6
    Last Post: 03-18-2017, 09:00 AM
  5. Tablet in-car install questions
    By RickJames8 in forum Google Nexus 7 Tablet (2013)
    Last Post: 03-17-2017, 11:17 PM
