1. AC Question's Avatar
    Samsung Galaxy S7 Edge makes a stock musical riff whenever a Bluetooth connection is made. For example, I connect the Bluetooth at a Bluetooth speaker. The sound happens. I connect the Bluetooth to my Fitbit. The sound happens. No this wouldn't be so bad (though I wish I knew where to look to disable this), but the phone will periodically do it by itself. It appears completely random. But it MIGHT be that a Bluetooth device "disconencted" and then "reconnected". Thus the original problem. I can't do without Bluetooth devices. But the sounder is making myself and other people crazy.
    03-18-2017 02:02 PM
  2. Tim1954's Avatar
    Press volume button, the volume control should pop down, tap the down arrow icon in top right corner. Another menu should drop down. There you have the granulated volume controls - try turning off the systems one...
    03-18-2017 10:59 PM
  1. what is the best email apps
    By Tim Bell1 in forum Samsung Galaxy S7 edge
    Last Post: 05-18-2017, 01:16 AM
  2. Galaxy S5 loses 4GLTE and needs to restart to reactivate 4GLTE
    By streetrods02 in forum Samsung Galaxy S5
    Last Post: 03-28-2017, 11:53 AM
  3. Replies: 1
    Last Post: 03-19-2017, 01:27 PM
  4. why is a screen overlay popping up on my Alcatel touch idol 3
    Last Post: 03-18-2017, 10:01 PM
  5. Replies: 1
    Last Post: 03-18-2017, 02:46 PM
